Good morning all. I have a minor issue with my 2016 Civil 3D, I assume its a system variable or something that was changed in error. Actually there are 4 of us using this version and 2 this works for, and 2 of us it doesn't.
Here is the issue: If I import new points to a point group, then create a surface from it, and I am in Model Space, when I change the scale from 1:1000 to 1:100 the cogo points and text should reduce in size. They do not. If I click on one of the points and "regenall" then they will resize based on the scale. 2015 Civil this works like it should, just change the scale and the points/text change size, but in 2016 it will not work.
I have done Google searches and can't seem to narrow my search down to something this specific. I have tried lots of settings mentioned in other posts I have found, but no luck so far.
Any ideas would be greatly appreciated.
Thanks
