Rage221677 Posted November 6, 2015 Posted November 6, 2015 I have a question involving pdf paper size settings. Here is my situation: I have a printer setting set for printing out 11x17 isometric drawings, I also have "Apply to Layout" set to these settings. Now I want to create a pdf of my isometric drawing using "DWG to PDF". In doing so, when I change from my "Apply to Layout" setting to "DWG to PDF", my paper size changes. It is still a 11x17 setting but not the correct one. I have been using 2014 AutoCAD and noticed when I made the same change from printing at a set printer to creating a pdf, the correct paper size was set automatically. Now I have 2015 AutoCAD and when I replicate the task, an incorrect paper size setting is chosen, I have to manually change it to the correct one. As I mentioned above, in 2014, the correct paper size setting was chosen and in 2015, it is not. I do not have a problem having to change it manually but I was wondering if there is a way to set it automatically. If anyone knows any information regarding this subject, I would greatly appreciate any assistance. Have a Blessed Day Quote
BIGAL Posted November 8, 2015 Posted November 8, 2015 You can save your current plot settings under a different name, top left on plot screen, do this in your master template, you can also import this setting from say your template. I use a lisp with different plot settings just pick from a menu as another way. Quote
RobDraw Posted November 9, 2015 Posted November 9, 2015 Is this what you are looking for? In order for it to work, the same paper size has to be available for the printer. Quote
