O'Huggin Posted November 11, 2015 Posted November 11, 2015 Attached is a print-out of the reduced building I am trying to assemble. I am intending to save a Revit file, just capturing the problem portion so that it can be accessible for diagnoses. But still, I can only go down to 884 kbytes, over the allowable 500 kbytes to upload. So, I settled to pdf-ing. It shows two corners, 3 wall forming a U (as seen in plan). The walls are all of the same type and were created in identical procedure. What I don't know is why the right one is misbehaving with the appearance of unnecessary multiple vertical lines while the left part is clean. I tried to use the trim (fillet) command, or right clicked on the grip, then disallowed joining so that I can manually meet the walls, or used the wall joins command but it won't get fixed. What is the best way to clean this corner? I wish I could have the actual file uploaded. Wall Unable to Join.pdf Quote
welldriller Posted November 17, 2015 Posted November 17, 2015 Is your right wall inserted as a "block" by any chance ? Quote
profcad Posted November 18, 2015 Posted November 18, 2015 On the wall join tool, try switching it from butt to miter. Quote
nod684 Posted February 8, 2016 Posted February 8, 2016 have you tried splitting the ends of both wall? split and delete the end walls and join them again Quote
