mkisno4 Posted November 12, 2015 Posted November 12, 2015 Hi again everyone. I had a sheet list set up with the publish command with all my sheets/drawings. However, unfortunately, I had to move the files to a different location last week. Today I opened up the publish command and loaded in my sheet list, but now all my sheets (understandably) cannot be found. It gives me a "Drawing not found" error under "Status". It's not the end of the world if I have to set it all up again, but I figured I'd ask first...is there anyway to quickly 'relink' or change the source of my sheets to the correct location? The files are all named the same thing, just in a different folder. Quote
zendrix Posted April 8, 2020 Posted April 8, 2020 i have same issue. did you find a solution? Thanks Quote
rkmcswain Posted April 8, 2020 Posted April 8, 2020 You can open the .DSD file in notepad and do a find+replace. Quote
