That would make total sense and I assure you I gave it some thought, lol, I promise ;) However, I have the command piggybacking with our plot command because most users tend to forget to change their initials so I took the liberty to do it programmatically. Its fine though really no big deal I was just curious.
I know this is a silly fix, but the user could just open the drawing as a read only if they just want to plot it. To speed it up a bit, you could have it not run in your plot lisp routine if drawing is read only by checking if writestat is 0 (which is read only). You could also do it by checking the dbmod variable and if nothing is modified, then don't run the initial changing lisp.
  • Replies 20
  • tmelancon
    11
  • David Bethel
    3
  • Lee Mac
    3
  • marko_ribar
    1
