wimal Posted November 15, 2015 Posted November 15, 2015 The attached message is display when a layer creating in a new file using lisp code. how can I stop to display it. Is there a system variable to stop it (cad 2016) Quote
Tharwat Posted November 15, 2015 Posted November 15, 2015 Just check the small white box on the left side hand in the bottom and it should not appear again. Quote
wimal Posted November 15, 2015 Author Posted November 15, 2015 Just check the small white box on the left side hand in the bottom and it should not appear again. I saw it.But I need to stop the message before appearing it. Quote
Tharwat Posted November 15, 2015 Posted November 15, 2015 Is it appear again if you check that white box in the bottom ? Quote
CAD USER Posted November 17, 2015 Posted November 17, 2015 Just tick on to the left side empty small box, do not show this message again, then click on ok, it will not appear again. Quote
rkmcswain Posted November 17, 2015 Posted November 17, 2015 Is that ALL your lisp code is doing? See: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Non-photometric-light-message-appears-in-AutoCAD.html I see your need for an answer, since you may not be in control of the machine running this code. You want a way to CONTROL this dialog for anyone, not just yourself. Quote
