jjatho Posted November 16, 2015 Posted November 16, 2015 So much like there are names for Red, Yellow, Blue, etc. I want to know if I can make a custom name for a specific color. Our company logo is the color (112,0,0) and we're switching to using that color for lots of annotations and other design notes. Before we do this, is there a way to create a new named color, other than the standard 9 index colors? Basically, let's say our company name is "CraneCo"; can I make a default color called CraneCo that corresponds with (112,0,0)? Quote
Dana W Posted November 16, 2015 Posted November 16, 2015 Never seen that done, don't know of any way to do it. How about a layer using color 112,0,0 and put all your text on it. Quote
lrm Posted November 16, 2015 Posted November 16, 2015 One approach is to create a custom material and give it a name. Go to the Material Editor mateditoropen and click on the create icon at the bottom left. Choose one of the listed types (e.g., Plastic) or click New Generic material. Change the default RGB values to 112,0,0 and edit the name to what you want. Open the material browser and create a material library so others can access the material. Quote
jjatho Posted November 16, 2015 Author Posted November 16, 2015 Never seen that done, don't know of any way to do it. How about a layer using color 112,0,0 and put all your text on it. That's the secondary plan if I can't make a new color name. Quote
BIGAL Posted November 17, 2015 Posted November 17, 2015 (edited) Maybe just use "Craneco" and change a picked objects colour (defun c:craneco ( / obj) (setq obj (car (entsel))) (command "chprop" obj "" "C" "T" "112,0,0" "") ) Edited November 17, 2015 by BIGAL added obj locally Quote
jjatho Posted November 17, 2015 Author Posted November 17, 2015 Maybe just use "Craneco" and change a picked objects colour (defun c:craneco () (setq obj (car (entsel))) (command "chprop" obj "" "C" "T" "112,0,0" "") ) That's a pretty good option, thanks! Quote
Dana W Posted November 17, 2015 Posted November 17, 2015 My recommendation is to grow past changing object properties, and use definitive layers with the object properties set to By Layer. Quote
JGA Posted November 23, 2015 Posted November 23, 2015 Have a go at the AutoCAD Color Book Editor Quote
