Hello,
I've got a bunch of blocks, representing landscape objects (such as trees, bushes, etc..). I'm trying to build up a routine that reinserts selected block and after specifying min/max scale and min/max rotation the reinserted blocks should be at random scales and rotations. By now I do it manually (copying blocks, and then selecting each one by one, changing scale and rotation).
I'm not that good with lisp, Here's my try on this:
(defun c:test ( / att blk sel blksc blkrot )
   (if (setq sel (ssget "_+.:E:S" '((0 . "INSERT"))))
           (setq blk (LM:al-effectivename (ssname sel 0))
           (setq blksc (LM:randrange-Scale))
           (setq blkrot (LM:randrange-Rotation))
                 att (getvar 'attreq)
           (setvar 'attreq 0)
           (while (vl-cmdf "_.-insert" blk
           "_S" blksc
           "_R" blkrot
           (setvar 'attreq att)
;; Random in Range  -  Lee Mac
;; Returns a pseudo-random integral number in a given range (inclusive)
;I did some modifications here:
(defun LM:randrange-Scale ( scmin scmax )
(setq scmin (getreal "\nSpecify min scale:")
(setq scmax (getreal "\nspecify max scale:")
   (fix (+ scmin (* (LM:rand) (- scmax scmin -1))))
(defun LM:randrange-Rotation ( rotmin rotmax )
(setq rotmin (getint "\nspecify min rotation:")
(setq rotmax (getint "\nspecify max rotation:")
   (fix (+ rotmin (* (LM:rand) (- rotmax rotmin -1))))
;; Rand  -  Lee Mac
;; PRNG implementing a linear congruential generator with
;; parameters derived from the book 'Numerical Recipes'
(defun LM:rand ( / a c m )
   (setq m   4294967296.0
         a   1664525.0
         c   1013904223.0
         $xn (rem (+ c (* a (cond ($xn) ((getvar 'date))))) m)
   (/ $xn m)
;; Effective Block Name  -  Lee Mac
;; ent - [ent] Block Reference entity
(defun LM:al-effectivename ( ent / blk rep )
   (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
       (if
           (and
               (setq rep
                   (cdadr
                       (assoc -3
                           (entget
                               (cdr
                                   (assoc 330
                                       (entget
                                           (tblobjname "block" blk)
                              '("AcDbBlockRepBTag")
               (setq rep (handent (cdr (assoc 1005 rep))))
           (setq blk (cdr (assoc 2 (entget rep))))
   blk
Maybe rethink the method insert a block copy as many as required , then when you do the ssget you pick the block this returns block name and using (0 . "Insert")(2 . blkname) and it will go through all of them and randomise in one go if not happy do again.
I posted re random circles within a circle and was going to redo it so it was true random but no 2 circles touch, the obvious addition is to fill a boundary. Now the post was ???
The method you suggest sounds good. I just don't know if I'm using Lee's functions right on this (since I need user input for min and max scale variable).
I don't think that your random circles routine will work for me, since I don't fill the whole boundary, and I have overlapping blocks also (see the picture).
