Baber62 Posted November 20, 2015 Posted November 20, 2015 A colleague of mine forwarded me a lisp routine which determines the OS TQ tile reference, however, the tile reference is displayed in the command bar. Is there a way that the reference can be printed on the screen in model space. The coding provided is as below: ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQ () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (command "expert" "5") (command "ucs" "save" "UCS1" ) (command "ucs" "w" ) (setq P1 (getpoint "Pick suitable point ")) ;co ord (setq PEAST (car P1)) ;eastings (setq PNORTH (cadr P1)) ;northings (setq PEASTF (rtos PEAST 2 0)) ;conversion to string (setq PNORTHF (rtos PNORTH 2 0)) (setq TQEAST (substr PEASTF 2 2)) ;parts of coords (setq TQNORTH (substr PNORTHF 2 2)) (setq TQSQ (strcat TQEAST TQNORTH)) ;name of map (setq TQEASTSQ (atoi (substr PEASTF 4 2))) (setq TQNORTHSQ (atoi (substr PNORTHF 4 2))) (if (and (<= TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SW") ) (if (and (<= TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NW") ) (if (and (> TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SE") ) (if (and (> TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NE") ) ; (setq REPLY (strcat "Co-ordinates give TQ" TQSQ MAP)) (princ REPLY) (print) (setq MPATH "//Regensw2k-svr01/basemaps/1250/") ;@ path for os maps (setq DPATH (strcat MPATH "TQ" TQSQ MAP)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (command "ucs" "restore" "UCS1" ) (command "-LAYER" "F" "*B_PT,*E_BY,*T_BY,*BMER,*G_PT,*PL_B,*GRID,*HTPT,*R_CL" "C" "252" "*tq*" "C" "251" "*road" "C" "250" "*buildout,buildpk" "") (command "-LAYER" "F" "*8010010,*8010098,*8010321,*8010570,*8010571,*8010572,*8010573,*8010574,*8010575" "C" "252" "*G80*" "C" "251" "*8010021" "C" "250" "*8010001" "" ) ) ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQL () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (command "expert" "5") (command "ucs" "save" "UCS1" ) (command "ucs" "w" ) (setq P1 (getpoint "Pick suitable point ")) ;co ord (setq PEAST (car P1)) ;eastings (setq PNORTH (cadr P1)) ;northings (setq PEASTF (rtos PEAST 2 0)) ;conversion to string (setq PNORTHF (rtos PNORTH 2 0)) (setq TQEAST (substr PEASTF 2 2)) ;parts of coords (setq TQNORTH (substr PNORTHF 2 2)) (setq TQSQ (strcat TQEAST TQNORTH)) ;name of map (setq TQEASTSQ (atoi (substr PEASTF 4 2))) (setq TQNORTHSQ (atoi (substr PNORTHF 4 2))) (if (and (<= TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SW") ) (if (and (<= TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NW") ) (if (and (> TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SE") ) (if (and (> TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NE") ) ; (setq REPLY (strcat "Co-ordinates give TQ" TQSQ MAP)) (princ REPLY) (print) (setq MPATH "P:/CGG/CAD/Data/Mapping/LBI/TQ-May2005/") ;@ path for os maps (setq DPATH (strcat MPATH "TQ" TQSQ MAP)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (command "ucs" "restore" "UCS1" ) (command "-LAYER" "F" "*B_PT,*E_BY,*T_BY,*BMER,*G_PT,*PL_B,*GRID,*HTPT,*R_CL" "C" "252" "*tq*" "C" "251" "*road" "C" "250" "*buildout,buildpk" "") (command "-LAYER" "F" "*8010010,*8010098,*8010321,*8010570,*8010571,*8010572,*8010573,*8010574,*8010575" "C" "252" "*G80*" "C" "251" "*8010021" "C" "250" "*8010001" "" ) (command "expert" "0") ) ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQQl () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (COMMAND "UCS" "W") (SETQ TQ (getstring "\n TQ NUMBER ? ")) ;eastings (setq MPATH "P:/CGG/CAD/Data/Mapping/LBI/TQ-May2005/") ;@ path for os maps (setq DPATH (strcat MPATH TQ)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (COMMAND "UCS" "P") ) ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQQ () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (COMMAND "UCS" "W") (SETQ TQ (getstring "\n TQ NUMBER ? ")) ;eastings (setq MPATH "P:/CGG/CAD/Resources/OS-Data/") ;@ path for os maps (setq DPATH (strcat MPATH TQ)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (COMMAND "UCS" "P") (command "-LAYER" "F" "*B_PT,*E_BY,*T_BY,*BMER,*G_PT,*PL_B,*GRID,*HTPT,*R_CL" "C" "253" "*tq*" "C" "252" "*road" "") (command "-LAYER" "F" "*8010010,*8010098,*8010321,*8010570,*8010571,*8010572,*8010573,*8010574,*8010575" "C" "253" "*G80*" "C" "251" "*8010021" "") ) Thanks for your assist in advance guys. Quote
Least Posted November 20, 2015 Posted November 20, 2015 Hows is this? ;;;http://www.cadtutor.net/forum/showthread.php?94664-OS-tile-references ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQ () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (command "expert" "5") (command "ucs" "save" "UCS1" ) (command "ucs" "w" ) (setq P1 (getpoint "Pick suitable point ")) ;co ord (setq PEAST (car P1)) ;eastings (setq PNORTH (cadr P1)) ;northings (setq PEASTF (rtos PEAST 2 0)) ;conversion to string (setq PNORTHF (rtos PNORTH 2 0)) (setq TQEAST (substr PEASTF 2 2)) ;parts of coords (setq TQNORTH (substr PNORTHF 2 2)) (setq TQSQ (strcat TQEAST TQNORTH)) ;name of map (setq TQEASTSQ (atoi (substr PEASTF 4 2))) (setq TQNORTHSQ (atoi (substr PNORTHF 4 2))) (if (and (<= TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SW") ) (if (and (<= TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NW") ) (if (and (> TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SE") ) (if (and (> TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NE") ) ; (setq REPLY (strcat "Co-ordinates give TQ" TQSQ MAP)) (princ REPLY) (print) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; PB - Metrix 2015 (SETQ DFLT 0) (SETQ TXTHG (GETVAR "textsize")) (PRINC "\nText Height: <") (PRIN1 TXTHG) (PRINC ">: ") (SETQ THGT (GETDIST)) (IF (= THGT nil) (SETQ THGT TXTHG) ) ; (SETQ PTXT (GETPOINT "\nLocate Text: ")) (setq old_layer (getvar "clayer")); Get current Layer (SETVAR "cmdecho" 0) ;(setq PTXT (getvar "viewctr")) (COMMAND "layer" "se" "text" "") (COMMAND "text" P1 THGT "" REPLY) (command "move" "last" "" PTXT pause) (command "_layer" "S" old_layer ""); reset Layer ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (setq MPATH "//Regensw2k-svr01/basemaps/1250/") ;@ path for os maps (setq DPATH (strcat MPATH "TQ" TQSQ MAP)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (command "ucs" "restore" "UCS1" ) (command "-LAYER" "F" "*B_PT,*E_BY,*T_BY,*BMER,*G_PT,*PL_B,*GRID,*HTPT,*R_CL" "C" "252" "*tq*" "C" "251" "*road" "C" "250" "*buildout,buildpk" "") (command "-LAYER" "F" "*8010010,*8010098,*8010321,*8010570,*8010571,*8010572,*8010573,*8010574,*8010575" "C" "252" "*G80*" "C" "251" "*8010021" "C" "250" "*8010001" "" ) ) ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQL () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (command "expert" "5") (command "ucs" "save" "UCS1" ) (command "ucs" "w" ) (setq P1 (getpoint "Pick suitable point ")) ;co ord (setq PEAST (car P1)) ;eastings (setq PNORTH (cadr P1)) ;northings (setq PEASTF (rtos PEAST 2 0)) ;conversion to string (setq PNORTHF (rtos PNORTH 2 0)) (setq TQEAST (substr PEASTF 2 2)) ;parts of coords (setq TQNORTH (substr PNORTHF 2 2)) (setq TQSQ (strcat TQEAST TQNORTH)) ;name of map (setq TQEASTSQ (atoi (substr PEASTF 4 2))) (setq TQNORTHSQ (atoi (substr PNORTHF 4 2))) (if (and (<= TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SW") ) (if (and (<= TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NW") ) (if (and (> TQEASTSQ 50)(<= TQNORTHSQ 50)) (setq MAP "SE") ) (if (and (> TQEASTSQ 50)(> TQNORTHSQ 50)) (setq MAP "NE") ) ; (setq REPLY (strcat "Co-ordinates give TQ" TQSQ MAP)) (princ REPLY) (print) (setq MPATH "P:/CGG/CAD/Data/Mapping/LBI/TQ-May2005/") ;@ path for os maps (setq DPATH (strcat MPATH "TQ" TQSQ MAP)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (command "ucs" "restore" "UCS1" ) (command "-LAYER" "F" "*B_PT,*E_BY,*T_BY,*BMER,*G_PT,*PL_B,*GRID,*HTPT,*R_CL" "C" "252" "*tq*" "C" "251" "*road" "C" "250" "*buildout,buildpk" "") (command "-LAYER" "F" "*8010010,*8010098,*8010321,*8010570,*8010571,*8010572,*8010573,*8010574,*8010575" "C" "252" "*G80*" "C" "251" "*8010021" "C" "250" "*8010001" "" ) (command "expert" "0") ) ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQQl () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (COMMAND "UCS" "W") (SETQ TQ (getstring "\n TQ NUMBER ? ")) ;eastings (setq MPATH "P:/CGG/CAD/Data/Mapping/LBI/TQ-May2005/") ;@ path for os maps (setq DPATH (strcat MPATH TQ)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (COMMAND "UCS" "P") ) ;*** TQMAP ; prog to work which tq square is req ; the path to the tq sqs is in the prog ;if location of maps changes then this line has to change @ ;*** (defun C:TQQ () (command "setvar" "insunits" "0") (command "setvar" "insunitsdefsource" "0") (command "setvar" "insunitsdeftarget" "0") (graphscr) (COMMAND "UCS" "W") (SETQ TQ (getstring "\n TQ NUMBER ? ")) ;eastings (setq MPATH "P:/CGG/CAD/Resources/OS-Data/") ;@ path for os maps (setq DPATH (strcat MPATH TQ)) (command "-layer" "make" "xrefs" "") (command "-xref" "O" DPATH "0,0" "" "" "") (COMMAND "UCS" "P") (command "-LAYER" "F" "*B_PT,*E_BY,*T_BY,*BMER,*G_PT,*PL_B,*GRID,*HTPT,*R_CL" "C" "253" "*tq*" "C" "252" "*road" "") (command "-LAYER" "F" "*8010010,*8010098,*8010321,*8010570,*8010571,*8010572,*8010573,*8010574,*8010575" "C" "253" "*G80*" "C" "251" "*8010021" "") ) Quote
Least Posted November 20, 2015 Posted November 20, 2015 Do you have a lisp that does any off the other tiles? P Quote
Baber62 Posted November 20, 2015 Author Posted November 20, 2015 Hi Least, It does the trick fine, however, just one slight modification need an arrow to point to the location clicked. Can the text be multi-line text with arial font? thanks Quote
Baber62 Posted November 20, 2015 Author Posted November 20, 2015 I don't have access at the current to any other tiles than the TQ tiles, however, when I get home this evening I should have access to other tiles up and down the UK and I will give it a go and let you know of the results. Quote
Least Posted November 20, 2015 Posted November 20, 2015 The only way I could get that to work is to make an attributed block and insert it at 'P1' with the attribute containing the variable 'REPLY'. Maybe somebody a little bit more clued up will come along, I'm a little bit up to my ears right now. P Quote
Baber62 Posted November 20, 2015 Author Posted November 20, 2015 Hi Least, Tried it with these co-ordinates 548237,099194, this is a location down south near the coast in Seaford. It put up on screen co-ordinates give TQ4891NW, whereas using the UK grid finder it gives "TV 48237 99194" so the TQ change in value to TV. Therefore this lisp while it ok for say the London area it doesn't cover the whole of the UK. I will try and get hold of the corner co-ordinates for each of the TQ or TV or T? tiles and take it from there. Thanks for your assist. Quote
eldon Posted November 20, 2015 Posted November 20, 2015 You are using the lisp programme outside its quoted parameters. It is titled for TQ tiles only, so you should not expect it to give you a TV tile If you look into the workings, it expects a Northing of six significant figures, and your example only had five significant figures (the leading zero is not a significant figure), so no wonder it is giving unexpected results. The OS has quite a good tile finder on line Quote
