PaulJC Posted November 20, 2015 Posted November 20, 2015 I'm losing my mind trying to solve a problem and stumbled across this forum while looking through google... I have an irregularly shaped item that i need to have holes (0.74mm) angled perpendicular to a face radiused in 2 directions, I have created an additional sketch to provide the hole locations but when trying to use the hole wizard i keep getting presented with an error even though when placing the holes in £D Sketch they preview correctly as to how i need them... Can anybody show me how to solve this problem? Solidworks 2013 Many Thanks in advance... Paul Quote
shift1313 Posted November 26, 2015 Posted November 26, 2015 Hole wizard creates a revolve of the profile. Im not sure what you mean by radiused in 2 directions but are you able to create one instance ok? Just not multiples? Quote
ILoveMadoka Posted December 10, 2015 Posted December 10, 2015 I've had instances where I could not get the hole wizard to work and I ended up having to model the holes using sketches & extrude cuts. Quote
