I have what will probably be a basic question for a lot of you. It revolves around LISP programming, IF statements and looping. See the code below just as a simple example.
Basically what I am trying to get is..using the IF statement against two real number variables.. if "A" is larger than "B", I want the user to be alerted to this fact, and then redirected to the top of the program to input the variables again. And if "A" is not larger, then do nothing. Any help would be greatly appreciated. Thanks
(defun c:testif ()
(setq a (getreal "\nEnter a Number : ")
      b (getreal "\nEnter Second Number : ")
);setq
(if (> a b)
	(prompt "\nFirst number is larger")
);if
);defun
(defun c:testif	(/ a b)
 (while
     )					;setq
     (cond ((or (not a) (not b))
     (prompt "\nPlease specify the values")
     T
    ((> a b) (prompt "\nFirst number is larger") T)
    (T nil)
     );cond
   );progn
 );while
Make the input a seperate defun within the body of your master code the other way is to swap a & b
(defun testif ()
(alert "Enter Val1 less than val 2")
   );setq
   (if (> a b)
        (Alert "First number is larger\n please try again")
        (testif)
   );if
);defun
master code .....
(testif) ; returns a < b
Thanks so much :)
You're welcome
(defun testif ()
   );setq
   (if (> a b)
        (testif)
   );if
);defun
master code .....
Thanks bigal! What if I were to have more than just the two variables. For instance, maybe i had 6 variables (a,b,c,d,e,f) and wanted to compare "a against b", then "c against d", and "e against f". Would I simply write the same code you have suggested above, 3 times consecutively? Just replacing the variable names.
I think using the swap is maybe easier but yes
(testif)
(setq vala a
(setq valb b)
(testif)
(setq valc a
vald b)
(testif)
(setq vale a
valf b)
Assuming I have understood what you are looking to achieve, here is another method, allowing for any number of values:
(defun c:test ( / l x )
   (if (setq x (getreal "\nEnter a number: "))
           (setq l (list x))
           (while (setq x (getreal (strcat "\nEnter a number greater than " (rtos (car l)) " <done>: ")))
               (if (<= x (car l))
                   (princ (strcat "\nNumber must be greater than " (rtos (car l))))
                   (setq l (cons x l))
   (reverse l)
