shamrocks Posted December 29, 2008 Posted December 29, 2008 Hi, I have two lines, that if extended, will meet at a particular point. So, is there an easy way to extend both lines until they reach that point, or do I have to draw each extension manually? Thanks Quote
chelsea1307 Posted December 29, 2008 Posted December 29, 2008 have your tried the command fillet? unless youve changed your acad.pgp the command is f, then for radius select 0, im assuming you want them to come together at a point. Then selct the two lines you want joined. Careful where u pick on your lines beacuse acad can do some wierd things with fillet. pick closest to the side that you want to come together at a point. Hope this helps Quote
shamrocks Posted December 29, 2008 Author Posted December 29, 2008 Hi chelsea, That is exactly what I was trying to do. Never knew you could just use '0' for Radius in Fillet. Much apprecaited. Kind REgards Russ Quote
sumeetppatel Posted January 5, 2009 Posted January 5, 2009 couldn't we use extend command, with extend on in edge option to make the lines meet at there extension point? Quote
David Bethel Posted January 5, 2009 Posted January 5, 2009 CHAMFER also works with distance set to 0. -David Quote
