Casio47 Posted November 24, 2015 Posted November 24, 2015 Hello All, I have a rectangle, and I wish to move the entire rectangle to be exactly 16'10" from a line (which represents a wall). The rectangle need not rotate, just move over and be positioned parallel to the wall Thanks Architecture 2013 Quote
steven-g Posted November 24, 2015 Posted November 24, 2015 Without seeing a drawing the exact method may vary slightly, but you need to use the command modifier "from". Select the rectangle and start the move command, pick the point on the rectangle that needs to be moved the distance from the wall. When you are prompted for the displacement point, type the word "from", you will be promted to pick a point (the point on your wall), now move the cursor in the direction you wish to move the rectangle and type in the distance, followed by enter. This will depend on you being able to use snap points as reference points, but hopefully will point you in the right direction Quote
Casio47 Posted November 24, 2015 Author Posted November 24, 2015 Wow...it actually worked, thanks Quote
steven-g Posted November 24, 2015 Posted November 24, 2015 You are welcome. I'm just happy you could understand my description Quote
RobDraw Posted November 24, 2015 Posted November 24, 2015 This can be done with Object Snap Tracking, also. Quote
TheCADnoob Posted November 24, 2015 Posted November 24, 2015 WOOT! salting away FROM into my library! thanks. edit:looks like rob beat me to it. I think they have done away with the need to use it in most circumstance though. If you move your object to the object you want the distance from you can just execute the move command and if your polar tracking and snap tracking is on just type in the distance and it will place it that distance form the the other object. That being said its not always easy to get into position to do this so FROM is definitely going in my toolbox. Quote
