Many Lisp files combine in one Lisp file...
CAD USER
I have so many Lisp files, any possibility to all lisp combine in one Lisp file??
Thanks in advance..
sure , paste them all in one file , for example mylisp.lsp. Just load this file every time and any function defined in mylisp.lsp will be available to you.
gr. Rlx
If you want 1 lisp have a think about a library lisp ie where you have just previously copied and pasted well tested code that you have put into multiple lisps and make them a defun, our auto load just has an emphasis on all the keyboard shortcuts rather than the code.
You can use a (if (not mydefuname )(load "mydefuname")) so only load as required, again the if not finds my individual library code rather than say 30 programs in one lisp. This is simple for run from a menu command.
I have again started moving code to a more multi defun approach not the copy and paste. New enter values use my auto create dialouge box routines "Getvals.lsp" this is like 3 lines of code and you have dialouge box entry rather than command line.
Have a think about how many times in all your code you ask for say getstring or getreal repeatedly.
The AutoLoad function enables a user to load an AutoLISP file when a specific command is entered at the command line.
(autoload "COPY0" '("COPY0"))
(autoload "COPYCOMMAND" '("ZZZ"))
(autoload "COVER" '("COVER"))
(autoload "DIMFLIP" '("DIMFLIP"))
Thanks, Dear, rlx & Dear Bigal......
You're welcome , lots of information on this site as well Lee's site. I have several functions I use quite often. Just remember if you ever sent somebody one of your routines to include either your 'library lisp' or include the function used by the another lisp program. It's not unlike xref's , it's a LispRef :-)
Gr. Rlx
Edited by rlx
Ok, rlx, I will do that??? thanks once again for everything...
or you can use the concatenate in ms dos, you can combine 100 .lsp in just a second.
as simple as
copy *.lsp merged.lsp
the command copies all .lsp file then create a file merged.lsp and put them all in there. actually you can name it what ever you want.
  • 6 years later...
Need help
(defun c:combinelisps ()
(startapp "cmd" "_cd C:\Users\Company\Documents\Autodesk\Lisp file folder" "copy *.lsp merged.lsp"))
Go to bottom left of Windows type
cmd
cd \Users\Company\Documents\Autodesk\Lisp file folder
2.
So in lisp may need to use Shell rather than startapp.
3.
Save above as a batch file .BAT then use (startapp "C:\Users\Company\Documents\Autodesk\Lisp file folder\copylisp.bat")
Just a side note can add a security lisp by using, copy security.lsp+lisp1.lsp c:\somewhere\lisp1.lsp
Edited by BIGAL
6 hours ago, BIGAL said:
1.
cmd
2.
3.
cmd
You mean paste this to Notepad & change the extension as .bat (To create BAT File)
No need for cmd when you save as a bat file
For me by the time I have copied pasted and saved code made it work, I would have it all done using 1st manual method.
agree plus I dont want to automate updating the master lisp. could overwrite or lose code happend a few times so I always do it manually now.
BIGAL & mhupp:
Thanks a lot Guys who replied to my thread !
I was merging Lisps files to make hard copies on A3 size paper to study & upgrade purpose only not to execute lisp routes.
(To execute you can have max. 50 Lisps programs otherwise it makes you headache as per my knowledge)
Another way by Lisp:
(defun c:mergelisps ( / )
(vl-file-copy "c:/Users/Company/Documents/My Lisp programme/LISP1.lsp" "c:/Users/Company/Documents/My Lisp programme/Print_Purpose.lsp" T)
(vl-file-copy "c:/Users/Company/Documents/My Lisp programme/LISP2.lsp" "c:/Users/Company/Documents/My Lisp programme/Print_Purpose.lsp" T)
(vl-file-copy "c:/Users/Company/Documents/My Lisp programme/LISP3.lsp" "c:/Users/Company/Documents/My Lisp programme/Print_Purpose.lsp" T)
(vl-file-copy "c:/Users/Company/Documents/My Lisp programme/LISP4.lsp" "c:/Users/Company/Documents/My Lisp programme/Print_Purpose.lsp" T)
(vl-file-copy "c:/Users/Company/Documents/My Lisp programme/LISP5.lsp" "c:/Users/Company/Documents/My Lisp programme/Print_Purpose.lsp" T)
 (princ))
I want your help to upgrade the lisp with the below function
(vl-load-com)
(foreach lispfiles (vl-directory-files "c:/Users/Company/Documents/My Lisp programme" "*.LSP" 1)
Thanks a lot.
As lisp files are text in old days could just push a text file straight to printer from DOS, should still be able to do the same probably using Powershell.
Printing with Powershell and files in folders - Stack Overflow
Please dont ask me how to make it work !
Trying to remember copy filename | printer
Hey guys remember a dot matrix with a box of continuous paper hanging out the back, ideal for this task.
(vl-load-com)
Far as i know their isn't a limit on how many lisp you can have in one file. Tho I don't edit any lisp inside of the main file. Because when loading a lisp its all or nothing. meaning if you forget a ")" in one of the functions it will error and all other functions wont load either.
So if I am editing a function I will copy it to a new file edit it there make sure its working then put it back into the main file. to avoid this issue.
You got to tell it what to do
(vl-load-com)
  (load lispfiles) ;load I'm guessing?
  • 2 weeks later...
(vl-load-com)
I wrongly approach to the foreach function
