Hi.
Does anyone have a cork tree 3D block?
Thanks.
For Autocad? Doubtful. The only Cork tree model that I know of is at Xfrog: http://xfrog.com/product/JA13.html. You could purchase it in .3ds format and then import it into Autocad using the 3DSIN command. I don't know how the materials will work though? You would probably have to manually re-apply them, and the model itself will be extremely heavy, (Xfrog models are always very hi-poly), so you would have to be very careful about how many you place in your scene.
Have you thought about adding trees and plants in Photoshop after you render the model?
  • 2 weeks later...
Cad64, thanks for the tip, i'll use Photoshop.
Regards.
