Andrew1979 Posted December 8, 2015 Posted December 8, 2015 This is something that has been bugging me and I don't understand what the issue is. When I use DIMANGULAR to measure the angle between 2 lines, in the command prompt it will say 340 but the dimension will be 70degrees. What is happening? Doesn't make any sense and I don't know what settings I need to change to make the command prompt number correct. The 70 degrees in the dimension text is correct. Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 70 degrees is not a dimension; it's an angular measurement. Attach a copy of the drawing that is causing you such confusion. Quote
RobDraw Posted December 8, 2015 Posted December 8, 2015 70 degrees is not a dimension; it's an angular measurement. By definition, it is also a dimension. The length of a line is also a dimension. Quote
krishn1234 Posted December 22, 2015 Posted December 22, 2015 I use PCB editor. Place » Dimension » Angular [P, D, A] from the main menu Quote
