ColinPearson Posted December 8, 2015 Posted December 8, 2015 Hello world. I don't know anything about Dynamic Blocks but I was trying to learn the other day. In doing so, I opened the Block Authoring Palette but ever since then, every time I open my Block Editor, the palette is floating there in my way. I can close the palette, but every time I open the Block Editor, it's there again... Any ideas? Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 To show or hide the Block Authoring palettes in the Block Editor Click Insert tab Block panel Block Editor. In the Edit Block Definition dialog box, Under Block To Create or Edit, select a name from the list and then, click OK. Click Block Editor tab Manage panel Authoring Palettes. Quote
ColinPearson Posted December 8, 2015 Author Posted December 8, 2015 Thanks ReMark. I'm on 2012, so mine is a bit different, but from within the Block Editor, I have that same icon that was the final one you said to click... It makes the palette go away but it's there again the next time. Screenshot below: Quote
ColinPearson Posted December 8, 2015 Author Posted December 8, 2015 I guess it was pretty hard to see in the first shot, maybe this is better: Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 If it is in your way why not enable the Auto-Hide option? It will be there if you need it but unobtrusive in the meantime. You could even set Transparency to 10% so it will be barely visible. Quote
RobDraw Posted December 8, 2015 Posted December 8, 2015 Only some of my blocks have this show up. My guess is that there is something within the block definition that is causing it to pop up. Quote
ColinPearson Posted December 8, 2015 Author Posted December 8, 2015 I guess I can do that, just kind of weird that it won't go away. Mehhh, probably better to not worry about it too much Quote
ReMark Posted December 8, 2015 Posted December 8, 2015 You can make it go away permanently by deleting the four palettes from the CUI. In my opinion that is not a good idea but hardly anyone follows my advice so go for it:shock:. I won't be insulted. Quote
ColinPearson Posted December 9, 2015 Author Posted December 9, 2015 ReMark, you've helped me on several occasions! You too RobDraw. This thing is in every block since the other day and it won't stay docked - it comes up in the middle of the Block Editor screen every time, it's driving me nuts!! Quote
RobDraw Posted December 9, 2015 Posted December 9, 2015 I'm not sure you can do anything about it other than turning it off each time. Quote
ReMark Posted December 9, 2015 Posted December 9, 2015 Don't dock it. Enable Auto-Hide and set the transparency to 10%. Do it and move on. Quote
