Hello!
I was working in a drawing when I got a message asking me to save a recovery copy which I did, but now I can't open the original file. Everytime I try get this message: AutoCad Error Aborting - Fatal error: Unhandle access violation reading 0x3b639abe exception at 33ed3712h.
What is this and how can I fix it so I can go back to use my original drawing which is linked to some others?
You created a recovery file. Run "Recover" from the application menu on that file. If recovery is successful, "save as" the old file name.
I knew I should have closed this thread as soon as Rob posted the obvious answer to the question.
This thread has been cleaned and is now closed to prevent any further spamming.
This topic is now closed to further replies.
