Super purge lisp only works some of the time
So I am having trouble with a lisp routine that I wrote to purge everything from a drawing. The issue has to deal with the wblock command. It seems to work about half of the time, and then the other half of the time it errors on the _Y portion of the code, which I am confused by. My code is as follows
(defun c:superpurge (/ file path pathfile *error* oldecho olddia)
 (vl-load-com)
 (defun *error* (msg)   ;This defines the error function so that if something goes wrong, it exits quietly and resets the variables
   (if oldecho
     (setvar 'cmdecho oldecho)
   (if olddia
     (setvar 'CMDDIA olddia)
   (if (not
  (member msg '("Function cancelled" "quit / exit abort"))
 (setq oldecho (getvar 'CMDECHO)) ;I am setting the variable oldecho equal to the variable cmdecho
 (setvar "CMDECHO" 0)
 (setq olddia (getvar 'CMDDIA))
 (setvar "CMDDIA" 0)
 (cond
   ((or (= (getvar 'writestat) 0) ;If the drawing is read only or hasn't ever been saved ie Drawing1, then it won't run
 (= (getvar 'DWGTITLED) 0)
    (alert
      "\n Superpurge cannot be used in files that haven't been named or are read only."
   (t     ;This is the "else" portion of the cond statement
    (setq file (getvar "DWGNAME")) ;This gets the drawing name
    (setq path (getvar "DWGPREFIX")) ;This gets the drawing's path
    (setq pathfile (strcat path file)) ;This combines the two variables into one
    (repeat 3
      (vl-cmdf "._AECCPURGESTYLES")
      (while (eq (logand (getvar "cmdactive") 1) 1)
 (command "_Y")
    (command "._PURGE" "_A" "*" "_N")
    (command "._PURGE" "_R" "*" "_N")
    (command-s "-WBLOCK" pathfile "_Y" "*" "_Y")
    ;Here I am running wblock and saving over the current drawing
    (princ "\nYour drawing is now squeaky clean")
 (setvar "CMDECHO" oldecho)  ;Resetting the variable cmdecho to its original value
 (setvar "CMDDIA" olddia)
 (princ)    ;Exit quietly
So I have kept messing with it and read through the code numerous times and I can't find any errors. There doesn't seem to be any rhyme or reason for when it does and doesn't want to work, just that the wblock command doesn't want to always work. The only other improvement I can think of for the code is changing my repeat function for purging the styles into a while not statement that stops when purge styles gives "There are no unused styles." Is there a way to right a while statement that would accomplish this? I choose to do a repeat length of 3 just because I had never seen a scenario where I had to run it more than 3 times, but it would be more desirable to not have to run it Aeccpurgestyles again if there isn't a need because this is the slowest portion of the code.
Dunno about de rest of the code but I alwayz hated all the command echo's and so now I use
 (defun LG_Purge () (vla-purgeall (vla-get-activeDocument (vlax-get-acad-object))))
And you can call this function as often as you want.
Gr. Rlx
Be aware that this method will ignore redundant MLeader Styles.
RLX, thank you for that code, that is a useful way to get around the command echo's (I find them pretty obnoxious). Lee, so does the code miss all types of styles, like all the AECC styles (surface styles, line and curve, etc.), or only mleader styles? Lee, I tried to write a loop for the purge styles portion, but it doesn't keep going until every style is purged as I had hoped
(while (not whilestop)
   (setq whilestop t)
   (if (getvar "WRITESTAT")
     (command "_Y")
   (while (= (logand 1 (getvar "CMDACTIVE")) 1)
     (command "_Y")
     (setq whilestop nil)
   (setq whilestop t)
     (command "_Y")
     (command "_Y")
I used to use
 (command "-purge" "all" "*" "no")
you can als search for purger.lsp on http://jtbworld.com/autocad-purger-lsp
gr. Rlx
I'm afraid I couldn't say - I don't have experience working with the Vertical applications.
