Hi. I have some *.txt files with coordinates and i want to join them to one *.txt
Is it possible to do this with a lisp ?
Thanks
Quickly written:
(defun mergetxt ( lst out / ds1 ds2 str )
   (if (setq ds1 (open out "w"))
           (foreach txt lst
               (if (setq ds2 (open txt "r"))
                       (while (setq str (read-line ds2))
                           (write-line str ds1)
                       (close ds2)
           (close ds1)
           out
Call with list of text files to merge (in order) and filepath for merged text file, e.g.:
(mergetxt '("C:\\YourFile1.txt" "C:\\YourFile2.txt" "C:\\YourFile3.txt") "C:\\YourMergedFile.txt")
Hi Lee Mac . Thank you for the post. I try to use it but gives me this error
Command: MERGETXT
; error: too few arguments
Command: MERGETXT
You are not calling the function in the manner I have described - please re-read my post above.
Hi Lee Mac. I don't know how to continue this code.Can you finish it ?
Thanks
The function is already finished - it is ready to use in your program or at the console, in the manner I have described above.
Sorry Lee Mac. I can not understand the code.Is it posible to open a window and select the folder with this files ?
Thanks
Yes, you could use my Get Files Dialog function, e.g.:
(defun c:test ( / lst out )
   (if
       (and
           (setq lst (LM:getfiles "Select Text Files" nil "txt"))
           (setq out (getfiled "Output file" "" "txt" 1))
       (mergetxt lst out)
Thanks you Lee Mac for the help. I did what you said
;;------------------=={ Get Files Dialog }==------------------;;
;;  An analog of the 'getfiled' function for multiple files.  ;;
;;  Author: Lee Mac, Copyright © 2014 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  msg - Dialog box label; 'Select Files' if nil or "".      ;;
;;  def - Default directory; dwgprefix if nil or "".          ;;
;;  ext - File extension filter (e.g. "dwg;lsp"); "*" if nil  ;;
;;  Returns:  List of selected files, else nil                ;;
;;  Version 1.4    -    09-08-2014                            ;;
(defun LM:getfiles ( msg def ext / *error* dch dcl des dir dirdata lst rtn )
   (defun *error* ( msg )
       (if (= 'file (type des))
           (close des)
       (if (and (= 'int (type dch)) (< 0 dch))
           (unload_dialog dch)
       (if (and (= 'str (type dcl)) (findfile dcl))
           (vl-file-delete dcl)
       (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
   (if
       (and
           (setq dcl (vl-filename-mktemp nil nil ".dcl"))
           (setq des (open dcl "w"))
               (foreach x
                       "lst : list_box"
                       "    width = 40.0;"
                       "    height = 20.0;"
                       "    fixed_width = true;"
                       "    fixed_height = true;"
                       "    alignment = centered;"
                       "    multiple_select = true;"
                       "but : button"
                       "    width = 20.0;"
                       "    height = 1.8;"
                       "getfiles : dialog"
                       "    key = \"title\"; spacer;"
                       "    : row"
                       "        : edit_box { key = \"dir\"; label = \"Folder:\"; }"
                       "        : button"
                       "            key = \"brw\";"
                       "            label = \"Browse\";"
                       "    spacer;"
                       "    : row"
                       "        : column"
                       "            : lst { key = \"box1\"; }"
                       "            : but { key = \"add\" ; label = \"Add Files\"; }"
                       "        : column {"
                       "            : lst { key = \"box2\"; }"
                       "            : but { key = \"del\" ; label = \"Remove Files\"; }"
                       "    spacer; ok_cancel;"
                   (write-line x des)
               (setq des (close des))
               (< 0 (setq dch (load_dialog dcl)))
           (new_dialog "getfiles" dch)
           (setq ext (if (= 'str (type ext)) (LM:getfiles:str->lst (strcase ext) ";") '("*")))
           (set_tile "title" (if (member msg '(nil "")) "Select Files" msg))
           (set_tile "dir"
               (setq dir
                   (LM:getfiles:fixdir
                       (if (or (member def '(nil "")) (not (vl-file-directory-p (LM:getfiles:fixdir def))))
                           (getvar 'dwgprefix)
                           def
           (setq lst (LM:getfiles:updatefilelist dir ext nil))
           (mode_tile "add" 1)
           (mode_tile "del" 1)
           (action_tile "brw"
               (vl-prin1-to-string
                  '(if (setq tmp (LM:getfiles:browseforfolder "" nil 512))
                       (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir tmp)) ext rtn)
                             rtn (LM:getfiles:updateselected dir rtn)
           (action_tile "dir"
               (vl-prin1-to-string
                  '(if (= 1 $reason)
                       (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:fixdir $value))) ext rtn)
           (action_tile "box1"
               (vl-prin1-to-string
                       (lambda ( / itm tmp )
                           (if (setq itm (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" $value ")"))))
                               (if (= 4 $reason)
                                   (cond
                                       (   (equal '("..") itm)
                                           (setq lst (LM:getfiles:updatefilelist (set_tile "dir" (setq dir (LM:getfiles:updir dir))) ext rtn)
                                       (   (vl-file-directory-p (setq tmp (LM:getfiles:checkredirect (strcat dir "\\" (car itm)))))
                                       (   (setq rtn (LM:getfiles:sort (append rtn (mapcar '(lambda ( x ) (strcat dir "\\" x)) itm)))
                                                 lst (LM:getfiles:updatefilelist dir ext rtn)
                                   (if (vl-some '(lambda ( x ) (not (vl-file-directory-p x))) itm)
                                       (mode_tile "add" 0)
                                       (mode_tile "add" 1)
           (action_tile "box2"
               (vl-prin1-to-string
                       (lambda ( / itm )
                           (if (setq itm (mapcar '(lambda ( n ) (nth n rtn)) (read (strcat "(" $value ")"))))
                               (if (= 4 $reason)
                                   (setq rtn (LM:getfiles:updateselected dir (vl-remove (car itm) rtn))
                                   (mode_tile "del" 0)
           (action_tile "add"
               (vl-prin1-to-string
                       (lambda ( / itm )
                           (if
                               (setq itm
                                   (vl-remove-if 'vl-file-directory-p
                                       (mapcar '(lambda ( n ) (nth n lst)) (read (strcat "(" (get_tile "box1") ")")))
                           (mode_tile "add" 1)
                           (mode_tile "del" 1)
           (action_tile "del"
               (vl-prin1-to-string
                       (lambda ( / itm )
                           (if (setq itm (read (strcat "(" (get_tile "box2") ")")))
                               (setq rtn (LM:getfiles:updateselected dir (LM:getfiles:removeitems itm rtn))
                           (mode_tile "add" 1)
                           (mode_tile "del" 1)
           (if (zerop (start_dialog))
               (setq rtn nil)
   (*error* nil)
   rtn
(defun LM:getfiles:listbox ( key lst )
   (start_list key)
   (foreach x lst (add_list x))
   (end_list)
   lst
(defun LM:getfiles:listfiles ( dir ext lst )
   (vl-remove-if '(lambda ( x ) (member (strcat dir "\\" x) lst))
       (cond
           (   (cdr (assoc dir dirdata)))
           (   (cdar
                   (setq dirdata
                       (cons
                           (cons dir
                               (append
                                   (LM:getfiles:sortlist (vl-remove "." (vl-directory-files dir nil -1)))
                                   (LM:getfiles:sort
                                       (if (member ext '(("") ("*")))
                                           (vl-directory-files dir nil 1)
                                           (vl-remove-if-not
                                               (function
                                                   (lambda ( x / e )
                                                       (and
                                                           (setq e (vl-filename-extension x))
                                                           (setq e (strcase (substr e 2)))
                                                           (vl-some '(lambda ( w ) (wcmatch e w)) ext)
                           dirdata
(defun LM:getfiles:checkredirect ( dir / itm pos )
   (cond
       (   (vl-directory-files dir) dir)
       (   (and
               (=  (strcase (getenv "UserProfile"))
                   (strcase (substr dir 1 (setq pos (vl-string-position 92 dir nil t))))
               (setq itm
                   (cdr
                       (assoc (substr (strcase dir t) (+ pos 2))
                               ("my documents" . "Documents")
                               ("my pictures"  . "Pictures")
                               ("my videos"    . "Videos")
                               ("my music"     . "Music")
               (vl-file-directory-p (setq itm (strcat (substr dir 1 pos) "\\" itm)))
           itm
       (   dir   )
(defun LM:getfiles:sort ( lst )
   (apply 'append
       (mapcar 'LM:getfiles:sortlist
           (vl-sort
               (LM:getfiles:groupbyfunction lst
                   (lambda ( a b / x y )
                       (and
                           (setq x (vl-filename-extension a))
                           (setq y (vl-filename-extension b))
                           (= (strcase x) (strcase y))
               (function
                       (and
                           (setq x (vl-filename-extension (car a)))
                           (setq y (vl-filename-extension (car b)))
                           (< (strcase x) (strcase y))
(defun LM:getfiles:sortlist ( lst )
   (mapcar (function (lambda ( n ) (nth n lst)))
       (vl-sort-i (mapcar 'LM:getfiles:splitstring lst)
           (function
                   (while
                       (and
                           (setq x (car a))
                           (setq y (car b))
                           (= x y)
                       (setq a (cdr a)
                             b (cdr b)
                   (cond
                       (   (null x) b)
                       (   (null y) nil)
                       (   (and (numberp x) (numberp y)) (< x y))
                       (   (= "." x))
                       (   (numberp x))
                       (   (numberp y) nil)
                       (   (< x y))
(defun LM:getfiles:groupbyfunction ( lst fun / tmp1 tmp2 x1 )
   (if (setq x1 (car lst))
           (foreach x2 (cdr lst)
               (if (fun x1 x2)
                   (setq tmp1 (cons x2 tmp1))
                   (setq tmp2 (cons x2 tmp2))
           (cons (cons x1 (reverse tmp1)) (LM:getfiles:groupbyfunction (reverse tmp2) fun))
(defun LM:getfiles:splitstring ( str )
       (lambda ( l )
           (read
               (strcat "("
                   (vl-list->string
                       (apply 'append
                           (mapcar
                               (function
                                   (lambda ( a b c )
                                       (cond
                                           (   (= 92 b)
                                               (list 32 34 92 b 34 32)
                                           (   (or (< 47 b 58)
                                                   (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                                                   (and (= 46 b) (< 47 a 58) (< 47 c 58))
                                               (list b)
                                           (   (list 32 34 b 34 32))
                               (cons nil l) l (append (cdr l) '(( )))
       (vl-string->list (strcase str))
(defun LM:getfiles:browseforfolder ( msg dir flg / err fld pth shl slf )
   (setq err
       (vl-catch-all-apply
           (function
               (lambda ( / app hwd )
                   (if (setq app (vlax-get-acad-object)
                             shl (vla-getinterfaceobject app "shell.application")
                             hwd (vl-catch-all-apply 'vla-get-hwnd (list app))
                             fld (vlax-invoke-method shl 'browseforfolder (if (vl-catch-all-error-p hwd) 0 hwd) msg flg dir)
                       (setq slf (vlax-get-property fld 'self)
                             pth (LM:getfiles:fixdir (vlax-get-property slf 'path))
   (if slf (vlax-release-object slf))
   (if fld (vlax-release-object fld))
   (if shl (vlax-release-object shl))
   (if (vl-catch-all-error-p err)
       (prompt (vl-catch-all-error-message err))
       pth
(defun LM:getfiles:full->relative ( dir path / p q )
   (setq dir (vl-string-right-trim "\\" dir))
   (cond
       (   (and
               (setq p (vl-string-position 58  dir))
               (setq q (vl-string-position 58 path))
               (/= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
           path
       (   (and
               (setq p (vl-string-position 92  dir))
               (setq q (vl-string-position 92 path))
               (= (strcase (substr dir 1 p)) (strcase (substr path 1 q)))
           (LM:getfiles:full->relative (substr dir (+ 2 p)) (substr path (+ 2 q)))
       (   (and
               (= (strcase dir) (strcase (substr path 1 q)))
           (strcat ".\\" (substr path (+ 2 q)))
       (   (= "" dir)
           path
       (   (setq p (vl-string-position 92 dir))
           (LM:getfiles:full->relative (substr dir (+ 2 p)) (strcat "..\\" path))
       (   (LM:getfiles:full->relative "" (strcat "..\\" path)))
(defun LM:getfiles:str->lst ( str del / pos )
   (if (setq pos (vl-string-search del str))
       (cons (substr str 1 pos) (LM:getfiles:str->lst (substr str (+ pos 1 (strlen del))) del))
       (list str)
(defun LM:getfiles:updatefilelist ( dir ext lst )
   (LM:getfiles:listbox "box1" (LM:getfiles:listfiles dir ext lst))
(defun LM:getfiles:updateselected ( dir lst )
   (LM:getfiles:listbox "box2" (mapcar '(lambda ( x ) (LM:getfiles:full->relative dir x)) lst))
   lst
(defun LM:getfiles:updir ( dir )
   (substr dir 1 (vl-string-position 92 dir nil t))
(defun LM:getfiles:fixdir ( dir )
   (vl-string-right-trim "\\" (vl-string-translate "/" "\\" dir))
(defun LM:getfiles:removeitems ( itm lst / idx )
   (setq idx -1)
   (vl-remove-if '(lambda ( x ) (member (setq idx (1+ idx)) itm)) lst)
(vl-load-com)
(defun c:mergetxt ( lst out / ds1 ds2 str )
           (foreach txt lst
                       (close ds2)
           (close ds1)
           out
   (if
       (and
       (mergetxt lst out)
But gives me this message
Command: TEST
; error: no function definition: MERGETXT
Sorry my mistake Lee Mac .I fix it
;;  Arguments:                                                ;;
           (close des)
           (unload_dialog dch)
   (if
       (and
               (foreach x
                       "lst : list_box"
                       "    width = 40.0;"
                       "    height = 20.0;"
                       "but : button"
                       "    width = 20.0;"
                       "    height = 1.8;"
                       "getfiles : dialog"
                       "    : row"
                       "        : button"
                       "            key = \"brw\";"
                       "    spacer;"
                       "    : row"
                       "        : column"
                       "        : column {"
                   (write-line x des)
           (set_tile "dir"
               (setq dir
                   (LM:getfiles:fixdir
                           (getvar 'dwgprefix)
                           def
           (mode_tile "add" 1)
           (mode_tile "del" 1)
           (action_tile "brw"
               (vl-prin1-to-string
           (action_tile "dir"
               (vl-prin1-to-string
                  '(if (= 1 $reason)
           (action_tile "box1"
               (vl-prin1-to-string
                               (if (= 4 $reason)
                                   (cond
                                       (mode_tile "add" 0)
                                       (mode_tile "add" 1)
           (action_tile "box2"
               (vl-prin1-to-string
                       (lambda ( / itm )
                               (if (= 4 $reason)
                                   (mode_tile "del" 0)
           (action_tile "add"
               (vl-prin1-to-string
                       (lambda ( / itm )
                           (if
                               (setq itm
                           (mode_tile "add" 1)
                           (mode_tile "del" 1)
           (action_tile "del"
               (vl-prin1-to-string
                       (lambda ( / itm )
                           (mode_tile "add" 1)
                           (mode_tile "del" 1)
               (setq rtn nil)
   (*error* nil)
   rtn
   (start_list key)
   (end_list)
   lst
       (cond
           (   (cdar
                   (setq dirdata
                       (cons
                           (cons dir
                               (append
                                   (LM:getfiles:sort
                                           (vl-remove-if-not
                                               (function
                                                   (lambda ( x / e )
                                                       (and
                           dirdata
   (cond
       (   (and
               (setq itm
                   (cdr
           itm
       (   dir   )
   (apply 'append
           (vl-sort
                       (and
               (function
                       (and
           (function
                   (while
                       (and
                           (setq x (car a))
                           (setq y (car b))
                           (= x y)
                       (setq a (cdr a)
                             b (cdr b)
                   (cond
                       (   (null x) b)
                       (   (null y) nil)
                       (   (= "." x))
                       (   (numberp x))
                       (   (numberp y) nil)
                       (   (< x y))
               (if (fun x1 x2)
       (lambda ( l )
           (read
               (strcat "("
                   (vl-list->string
                       (apply 'append
                           (mapcar
                               (function
                                   (lambda ( a b c )
                                       (cond
                                           (   (= 92 b)
                                           (   (or (< 47 b 58)
                                               (list b)
   (setq err
       (vl-catch-all-apply
           (function
       pth
   (cond
       (   (and
           path
       (   (and
       (   (and
       (   (= "" dir)
           path
       (list str)
   lst
   (setq idx -1)
(vl-load-com)
           (foreach txt lst
                       (close ds2)
           (close ds1)
           out
   (if
       (and
       (mergetxt lst out)
Thanks :D
jUst get as old as me COPY file1+file2 file3 just use STart CMD
I Hate a iPad never puts caps wher I want them
