Casusa Posted December 22, 2015 Author Posted December 22, 2015 I think the roofs of the buildings in the foreground should have some overhang and eaves. Also?~Lee Hi. How can i do this? Thanks. Quote
lrm Posted December 22, 2015 Posted December 22, 2015 Hi. How can i do this? Thanks. Create a closed polyline to form the shape of the roof similar to the following illustration then extrude it and reposition to yield the same overhang at each end of the building. In the following image I have added a tiled roof and stucco wall material created from images I downloaded. For the rendered image I turned on the sun and sky background. The ground is a noise map with using two shades of gray. There are many parameters you can tweak to get closer, but probably never achieve, the results you want. Have fun! ~Lee Quote
