Thicken surface - intersecting geometry error
Hello,
I am in the process of modeling a part with specific geometry that can not be altered. However, when I go through, copy to construction, stitch the model, and copy to surface again - then try thicken. An error code stating intersecting geometry - and that it can not complete task.
Is there a way around this? as changing the model is not an option.
Thanks.
Edited by logahoms1
You have posted in the Autocad section but it appears that this is a Solidworks question?
It wouldn't let me upload the AutoCAD inventor part due to size restrictions at 1.12 MB. So I uploaded the file that it would allow - which was the original surface. I am trying to thicken the surface in inventor after I imported it and "Saved As" to make an inventor part file.
So this is an Inventor question then? :unsure:
It is important to post questions in the correct area of the forum relating to the software you are using. If this is an Inventor question, let me know and I will move it to the Inventor section.
