Help me, Export dimension and number to excel
Hi, every body!
I have a drawing with dimensions and numbers.
Please help me a lisp Select Dimension and Number after export to Excel.
Thank you very much!
Edited by minhphuong_humg
(defun c:td(/ D_VAL PRE T_VAL XLACELL XLAPP)
 (setq xlApp (vlax-get-object "Excel.Application")
xlACell(vlax-get-property xlApp "ActiveCell")
pre 0); SET YOUR DIMENSION VALUE PRECISION HERE
 (setq t_val(vla-get-textstring (vlax-ename->vla-object (car(entsel"\nPick text: ")))))
 (vlax-put-property xlAcell "Value2" t_val)
 (setq d_val(rtos (vla-get-Measurement (vlax-ename->vla-object (car(entsel"\nPick dimension: ")))) 2 pre))
 (vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" d_val)
 (vlax-invoke-method (vlax-get-property xlAcell "OFFSET" 1 0) "Activate")
 (vlax-release-object xlApp)(vlax-release-object xlAcell)
(vl-load-com)
(vl-load-com)
Thank Dipesh Kalasaria very much!
But I run lisp is error.
Command: td
; error: bad argument type: VLA-OBJECT nil
Please, help me.
P/S:
You can edit help me Select by windows as Pick? Thank you.
Good luck for you!
start excel with new sheet and try again. this program will send text value and dimension value to excel
Thank Dipesh Kalasaria,
I'm try and ok.
But I have to repeat to much command "td".
Please, help me edit select by windows. Select (save temp), then finish export to excel.
Good luck for you!
All selection at once ? or Only one text and one dimension at once ?
I want Only one text and one dimension at once (save temp). After finish is export to Excel.
Please, help me.
(defun c:td(/ ENT1 ENT2 PRE SS XLACELL XLAPP)
pre 0 ; SET YOUR DIMENSION VALUE PRECISION HERE
ss(ssget '((-4 . "")))
(if (> (sslength ss) 2)(progn(princ"\nMore than two object selected...")(princ)(exit)))
(setq ent1 (vlax-ename->vla-object (ssname ss 0))
ent2 (vlax-ename->vla-object (ssname ss 1))
(if (= (vla-get-objectname ent1) "AcDbText")
(vlax-put-property xlAcell "Value2" (vla-get-textstring ent1))
(vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" (rtos (vla-get-Measurement ent2) 2 pre))
(vlax-put-property xlAcell "Value2" (vla-get-textstring ent2))
(vlax-put-property (vlax-get-property xlAcell "OFFSET" 0 1) "Value2" (rtos (vla-get-Measurement ent1) 2 pre))
(vl-load-com)
(vl-load-com)
Dear, Dipesh Kalasaria
Command: td
Select objects: 1 found
Select objects: 1 found, 2 total
Select objects: 1 found, 3 total
Select objects: 1 found, 4 total
Select objects:
More than two object selected...; error: quit / exit abort
First:
Open excel
Second:
Open file autocad, load lisp
CMD: td
select Dimension 1, number 1; select dimension 2, number 2.....
Finish.
Error...
Please, help me.
Good luck for you!
you just select one dimension and one text at once....if you select more that 2 object, program will show error
Thank Dipesh Kalasaria very much.
But, As I understand, it's not a much different approach (#2).
I mean:
Load lisp: td
select Dimension 1, Number1...contiunue Select Dimension 2, number 2,........., Finish (right mouse).
Export Excel.
And your lisp:
Select DM1, N1 -->right mouse
Select DM2, N2 -->right mouse
Finish.
repeat td to much.
Please, help me.
Good luck for you!
