Global attribute properties changes in a block?
Is there away to make global changes to attribute properties in a block?
Is there a command for that? I am interested in changing color & layers
in a group of blocks in a drawing.
Thank you,
Bedit brings up the block editor. I have changed properties in a block
but it does not chnage the attribute text color. Maybe there is a way
to change attributes in block editor.
While in the block editor select the attribute, you can edit the properties of the attribute in Properties. Be sure to use Attsync after you leave the block editor.
You might also want to try Battman.
