set a text object to value its properties
samifox
Hi
I have a true geographic drawing with object Z axis.
Usually I:
  1. execute “ID” command,
  2. select a point
  3. see the Z value
  4. set it as a text value
I want to automate it,
using “Field” I can only predefine the position of another object Z value.
I need the same behavior but with the position of the “field” text object. in other words, i need the field to mesure itself.
Is there a way to do it without lisping it?
Thanks
S
it can be done as a block attribute
perfect,
thank you
how did you do it?
ok folks ,
how an attribute can content out its properties (without the use of fields) ?
  • 3 weeks later...
perfect,
thank you
how did you do it?
sorry I was offline for a bit, holidays etc..
I made a block, added a block attribute, closed the block.
then turned the attribute into a field.
I don't know if is possible any other way.
