Hatch 3D polyline/ 3D figure
I am modeling a warped wall of a dam's sluiceway and I can't get the 3D polylines to hatch or fill in with any color. No single point of the polyline is in the same xyz plane, which is my problem. I have tried, and have access to, using Civil 3D also.
Will you be viewing this in 3d or just a 2d plan view? All I can think of now is to create a separate 2d polyline atop the 3d one and hatch it unless you'll be viewing in 3d in which case I'm unsure.
It will be viewed in 3D. I did use Civil 3D and created surfaces and put in really small contors. But it looks really cheesy and not a good solid color.
If you want it to be a solid color turn on your slopes and in your analysis set there to be only one range in the slopes. Then you can set your color to what you want. :wink:
