Anthony6697 Posted December 31, 2015 Posted December 31, 2015 I need help developing a lisp routine. I am not very familiar with writing code. I work for a M.E.P. Consulting Engineering firm and want to develop a lisp routine that by typing a few letters in AutoCAD for example "2x4" this would then automatically insert a 2x4 light block bypassing the scale option and put that block on our lighting layer and then go back to the original layer that AutoCAD was in. Please respond. Thank you for your time. Quote
tzframpton Posted December 31, 2015 Posted December 31, 2015 Try Tool Palettes instead... you can do all this without programming. Tool Palettes can be researched in the Help File. Quote
Anthony6697 Posted December 31, 2015 Author Posted December 31, 2015 Its quicker for me to just type a few words and then hit the space bar and continue the command if were inserting multiple and different blocks onto a drawing. Quote
tzframpton Posted December 31, 2015 Posted December 31, 2015 I wouldn't say it's quicker, I'd say it's equally as quick. Unless I'm not reading your inquiry correctly. Are you familiar with Tool Palettes at all by chance? Quote
Anthony6697 Posted December 31, 2015 Author Posted December 31, 2015 You know what.. Your Right. This is much easier to put together. Thank you. Quote
BIGAL Posted December 31, 2015 Posted December 31, 2015 If you wanted every 2x3 etc then you would need to define just so many little defuns for every insert, I would go the tool palette way like Tz but as an alternative you could look at a pop or ribbon menu this can have very simple sub menu's so you can have multiple subs for each type of insert. You just pass the block name to a preloaded lisp. Quote
