delkovebay Posted January 3, 2016 Posted January 3, 2016 Hello everyone! I have an lisp routine and I wish that he might set the path. (the same when you install the program -> you select the path in window and then click "OK") And assign a variable this path. Is it possible? Many thanks. Quote
BIGAL Posted January 3, 2016 Posted January 3, 2016 Can you post the code or supply some more information, also check Help for "findfile". Quote
delkovebay Posted January 4, 2016 Author Posted January 4, 2016 I want to obtain path by select folder and click OK (like at screen). After, assign variable this pat.h What command I must to write to call this method? Quote
delkovebay Posted January 4, 2016 Author Posted January 4, 2016 I've found some solution by Lee-Mac: http://www.lee-mac.com/directorydialog.html Quote
hanhphuc Posted January 4, 2016 Posted January 4, 2016 if you have Express Tool installed, maybe this? (setq path ([color="blue"]acet-ui-pickdir[/color])) Happy new year 2016 Quote
delkovebay Posted January 4, 2016 Author Posted January 4, 2016 if you have Express Tool installed, maybe this? (setq path ([color="blue"]acet-ui-pickdir[/color])) Happy new year 2016 Wow! It's amazing! Where can I see more about Express Tool? Quote
hanhphuc Posted January 4, 2016 Posted January 4, 2016 Where can I see more about Express Tool? HTH Quote
Lee Mac Posted January 4, 2016 Posted January 4, 2016 Wow! It's amazing!Where can I see more about Express Tool? There is no official documentation - here is some information compiled for a several of the functions. Quote
