How would someone create a title block for a sheet that has text that you fill in when you insert it in rel. 14?
Just to verify, we're talking Release 14 not AutoCAD 2014. Yes?
Not me guys. One of my former students with rel 14. I myself am in the process of modernizing. I scoped out the tutorial by the way. That should work. Thanks Rob...
For each entry in your title block you would substitute an attribute. All the attributes would be incorporated with your title block.
So, for example, let's say you show such information in your title block as Title, Designed By, Drawn By, Checked By, Approved By, any Dates, Job No., Scale, Drawing No., Issue, Sheet No., etc. all of these would be attributes.
So as each section of the title block is created, say: XXXXX = Client Name, you assign the clients name query to that section using the "attrib" command in?
"Client Name" will be an attribute. You may elect to assign a default value of "XXXXX" (or anything else) to the attribute when it is defined.
I suggested he upgrade by the way. His response was as follows:
I don't think I want to upgrade for now Timothy. I bought this license years ago. It took me years to open the box and I want to get my monies worth. For now, if it ain't broke, I ain't going to fix it. Darn, I just learned how to use it.
He originally learned architecture using Draftsight which is very similar to AutoCAD.
People who make that kind of statement about AutoCAD usually end up regretting that choice. R14 doesn't even work well on the newer versions of Windows. Draftsight is free and is a step or four ahead of R14.
