_undefine and _redefine command by lisp only on one drwawing
Hello guys, I've got a little problem!
I need to redefine the _copy and the _delete command in order to add some instruction to them.
2 problems:
1. I'm italian, the locate command for copy is "copia" and for delete "cancella"
I have to redefine all of them? What if someone has the german version of autocad?
exemple:
(defun C:copia (/ i selected )
 (IF (dcl-Form-IsActive Cobiax/Main)
   (princ "\n Selezionare gli alleggerimenti da copiare: ")
   (setq selected (ssget))
   (command "_.copy" selected "" pause pause)
 (conta_elementi nome)
   (redef "copia")
   (redef "_copy")
   (command "_.copy")
;(princ)
[ it possible to defun multiple commands at once?
(defun C:copy;copia;Kopie; ...) ]
2. Is it possible to have the redefined command only on the current drawing ?
Otherwise the lisp will fail on other drawings...
Thanks guys :)
Dennis
