Roy_043 Posted September 24, 2016 Posted September 24, 2016 Good catch Lee! Improved code below. ; (KGA_String_SliceChrSet "abc123cde456fgh789" "0123456789") => ("abc" "123" "cde" "456" "fgh" "789") (defun KGA_String_SliceChrSet (str chrSet / ret sub) (setq chrSet (vl-string->list chrSet)) (mapcar '(lambda (cur nxt) (if (or (not nxt) (vl-position (list (and (vl-position cur chrSet)) (and (vl-position nxt chrSet))) '((T nil) (nil T)) ) ) (progn (setq ret (cons (vl-list->string (reverse (cons cur sub))) ret)) (setq sub nil) ) (setq sub (cons cur sub)) ) ) (setq str (vl-string->list str)) (append (cdr str) '(nil)) ) (reverse ret) ) (defun MySort (lst) (setq lst (mapcar '(lambda (sub) (list (KGA_String_SliceChrSet (car sub) "0123456789") sub)) lst ) ) (mapcar 'cadr (vl-sort lst '(lambda (a b) (setq a (car a)) (setq b (car b)) (while (and (car a) (car b) (= (car a) (car b)) ) (setq a (cdr a)) (setq b (cdr b)) ) (if (and (car a) (car b) (wcmatch (car a) "#*") (wcmatch (car b) "#*") ) (< (atoi (car a)) (atoi (car b))) (< (car a) (car b)) ) ) ) ) ) Quote
marko_ribar Posted September 24, 2016 Posted September 24, 2016 Just to inform... Previously posted code in post #19 was unreliable... I revised it again, although result is the same - IMO correct... So if you wish, any further testing is appreciated... M.R. Quote
Roy_043 Posted September 25, 2016 Posted September 25, 2016 @ Lee: Your function LM:splitstring already 'escapes' the "\\" character. For obvious reasons it should also escape the "\"" character. Quote
Lee Mac Posted September 25, 2016 Posted September 25, 2016 Your function LM:splitstring already 'escapes' the "\\" character. For obvious reasons it should also escape the "\"" character. As you may have gathered, the original function was developed for the purpose of sorting filenames in which such character could not occur, but for general purpose this character should indeed be escaped: (defun mysort ( lst ) (mapcar '(lambda ( n ) (nth n lst)) (LM:alphanumsort-i (mapcar 'car lst))) ) ;; Alphanumerical Sort-i - Lee Mac ;; Sorts a list of strings containing a combination of alphabetical & numerical characters and returns the indices. (defun LM:alphanumsort-i ( lst ) (vl-sort-i (mapcar 'LM:splitstring lst) (function (lambda ( a b / x y ) (while (and (setq x (car a)) (setq y (car b)) (= x y) ) (setq a (cdr a) b (cdr b) ) ) (cond ( (null x) b) ( (null y) nil) ( (and (numberp x) (numberp y)) (< x y)) ( (numberp x)) ( (numberp y) nil) ( (< x y)) ) ) ) ) ) ;; Split String - Lee Mac ;; Splits a string into a list of text and numbers (defun LM:splitstring ( str ) ( (lambda ( l ) (read (strcat "(" (vl-list->string (apply 'append (mapcar (function (lambda ( a b c ) (cond ( (or (= 34 b) (= 92 b)) (list 32 34 92 b 34 32) ) ( (or (< 47 b 58) ;(and (= 45 b) (< 47 c 58) (not (< 47 a 58))) (and (= 46 b) (< 47 a 58) (< 47 c 58)) ) (list b) ) ( (list 32 34 b 34 32)) ) ) ) (cons nil l) l (append (cdr l) '(( ))) ) ) ) ")" ) ) ) (vl-string->list str) ) ) Quote
marko_ribar Posted March 17, 2019 Posted March 17, 2019 (edited) This with sorting list of strings is really mess... After you look whole code posted here : http://forums.augi.com/showthread.php?173343-Sorting-List-either-Alpha-Numeric-or-combined&p=#3 I beleive that you won't know what one sorting is the best for any descent purpose of doing so... Maybe the simplest coded as last example in posted link : (vl-sort l '<) ... Now when I look from different perspective I'd use this, although I am not familiar what was used for sorting - maybe bits of strings which are compared (it looks that ascii table isn't reference here)... So some more clarifications is needed here... Perhaps Lee knows, just guessing... Further more his AlphanumSort would yield perhaps even different than those 4 types from link I provided... Now I am really confused even more than I previously thought - was thinking that this issue is simple... [EDIT : I've checked it once again - it seems that (vl-sort l '<) is using ascii values - look at the end of posted link : (_sort-1 l) = (_sort-3 l) ; (_sort-4 l) = (vl-sort l '<)] Regards, M.R. Edited March 18, 2019 by marko_ribar Quote
