Different DXF data generated
Hi,
I was wondering if i could get some help here. I use AutoCAD LT 2005 here. My question is i had no idea why i am getting a different data in DXF format here. The following below is the one i got a while ago.
0
SECTION
2
HEADER
0
TEXT
5
22E673
330
199AC
100
AcDbEntity
8
MyDatapoint
48
3.0
100
AcDbText
10
310274.1366997352
20
5827918.583314535
30
0.0
40
1.0
1
T7610S
7
text2mm
100
AcDbText
Now, i got a different data when i started a drawing from scratch
0
TEXT
5
EC
330
1F
100
AcDbEntity
8
MyDatapoint
100
AcDbText
10
706.2562621262673
20
578.676195480436
30
0.0
40
2.5
1
T100S
100
AcDbText
The difference is that there are six steps down from "MyDataPoint" before it hits the X-Coordinate (for the first DXF) while it only takes 4 steps for the second DXF.
I don't know how to get the same data as i did before. I wonder if anyone would be able to help me out please.
Thank you in advance
The first example has additional 2 lines, "48" & "3.0".
Group Code 48 is linetype scale; so it must be one text had a linetype scale of 3.0 assignd to it. You may have had CELTSCALE set to 3 when the first example text was created.
