Chenna Siva Koteswara rao Posted December 31, 2008 Posted December 31, 2008 Sir, I received an AutoCad drawing for modifications. Drawing is not showing in Model Tab, but it is not showing in Layout Tab. Could you please advice me how to I get on Model tab this drawing for editing. Regards Rao Quote
Dipali Posted December 31, 2008 Posted December 31, 2008 Sir,I received an AutoCad drawing for modifications. Drawing is not showing in Model Tab, but it is not showing in Layout Tab. Could you please advice me how to I get on Model tab this drawing for editing. Regards Rao if it is showing in layout tab, you can use command 'chspace' to move it to model space. Quote
Chenna Siva Koteswara rao Posted December 31, 2008 Author Posted December 31, 2008 When I used this command, (chspace) it is showing as "There are no active Model space viewports". Please advice Quote
Dipali Posted December 31, 2008 Posted December 31, 2008 if there is any viewport click inside it. or if not, creat new viewport & than try again Quote
totzky Posted December 31, 2008 Posted December 31, 2008 Have you tried setting ti = 1 (ti-tilemode) and back to ti =0? Quote
rkmcswain Posted December 31, 2008 Posted December 31, 2008 I received an AutoCad drawing for modifications. Drawing is not showing in Model Tab, but it is not showing in Layout Tab. That makes no sense. You say it is not showing in the model or layout tab...? Quote
ReMark Posted December 31, 2008 Posted December 31, 2008 "Drawing is not showing in Model Tab, but it is not showing in Layout Tab..." [rubs eyes] Yep...that's what the OP said. Maybe he meant to say that it IS showing in the Model tab. That would make the most sense, right? Quote
Chenna Siva Koteswara rao Posted January 2, 2009 Author Posted January 2, 2009 "Drawing is not showing in Model Tab, but it is not showing in Layout Tab..." Sorry I typed wrong. Please find below corrected my statement Drawing is not showing in Model Tab, but it is showing in Layout Tab..." Rao Quote
totzky Posted January 2, 2009 Posted January 2, 2009 Create a viewport first by typing MVIEW. Then use CHSPACE command. Quote
rkmcswain Posted January 2, 2009 Posted January 2, 2009 Are there actually objects on MS? Maybe everything is in the layout? To check, switch to MS, thaw and turn on all layers, and zoom Extents. Quote
Chenna Siva Koteswara rao Posted January 6, 2009 Author Posted January 6, 2009 Create a viewport first by typing MVIEW.Then use CHSPACE command. Thanking you Sir. I got it now. It helped me lot and worked well for editing and modification. Regards, Rao Quote
Chenna Siva Koteswara rao Posted January 6, 2009 Author Posted January 6, 2009 This problem solved by Create a viewport first by typing MVIEW. Then use CHSPACE command. Thank You, I got it now. Regards, Rao Quote
boyo Posted January 14, 2009 Posted January 14, 2009 If in model tab you have different units set it may not be visible to a naked eye. Zoom extends should bring it to view then. Quote
