SLW210 Posted January 11, 2016 Posted January 11, 2016 Then you would run into the issue that SAFeSTeR was referring to. The width would need to be zero or the same as the length of the text string. And the same is true of your method, I just tried it with width set, unless you keep the text box size, columns, etc. it will not necessarily stay aligned. A routine of sorts to set all MTEXT appropriately or set them manual as needed (stated case manual should work), there is no guarantee, as already mentioned to maintain if edited. Quote
RobDraw Posted January 11, 2016 Posted January 11, 2016 Did you try the method that I described without columns as discussed already? That is the only thing that will throw it off. I use that method on a regular basis and it does work as described. Quote
