Max sea Posted January 8, 2016 Posted January 8, 2016 Hi, I would like to know if someone would be able to assist me in order to create a lisp routine to reduce the number of point along a polyline. In order words, I would like to smooth the line and few week ago someone mentioned a LISP routine buit I am not familiar at all with this routine. If anyone is able to assist me regarding this routine, I will appreciate it (How to create a smooth LISP routine and how to run it properly). Thanks for your time, Regards, Max Quote
Max sea Posted January 9, 2016 Author Posted January 9, 2016 Thanks Bigal for your input. It did help with a bit of work around. However, some vertices are deleted or added based on the weeding tools factors. I would like to keep those points and all I want is smoothing the line because it is too sharped. It might be feasible to use a least square method or other smoothing / Interpolating methods in order to create a "smooth" Polyline? Quote
BIGAL Posted January 10, 2016 Posted January 10, 2016 If you just want a smooth pline, pedit spline or fit is built in. Quote
nod684 Posted February 6, 2016 Posted February 6, 2016 Hi, I would like to know if someone would be able to assist me in order to create a lisp routine to reduce the number of point along a polyline. In order words, I would like to smooth the line and few week ago someone mentioned a LISP routine buit I am not familiar at all with this routine. If anyone is able to assist me regarding this routine, I will appreciate it (How to create a smooth LISP routine and how to run it properly). Thanks for your time, Regards, Max i think this should be in the Autolisp section.. anyway if you are wanting to remove points along a line you can use pedit... or you can google for Psimple.lsp by CAB ( Charles Alan Butler) i use it all the time Quote
