bruno_bdan
Automatization of the " ID " command
bruno_bdan
Hello everyone, my name is Bruno and this is my first post here!!:)
Is important to say that I work with cad since 2014. I'm good in 2-D , and I have a little of experience in 3-D drawning. I'm sorry, but I've never used a Lisp.
This is what is happening:
I was teaching numerical integration to my brother using autocad. I made a drawning and divide it into ten equally spaced segments, as showed below.
I used " ID " to get the length of each chord, so I could paste into a excel sheet and calculate the area.
My doubt is: Is there any way to get the ID of multiple lines without click one by one?
This is fine when you divide a drawning into 100 , 1000 or 1 000 000 of spaces.
Cheers!!
Share this post
Link to post
Grrr
Hi Bruno,
You could use "point manager" from Lee Mac to get the coordinates of the intersection points (ofcourse you would need 2nd lisp to place those point objects at each intersection),
or if you want directly to check the area - create a hatch or bpoly and look into its properties.
Share this post
Link to post
Lee Mac
Welcome to CADTutor Bruno!
Please try the following:
[color=GREEN];; Integration Demonstration  -  Lee Mac[/color]
([color=BLUE]defun[/color] c:integrate ( [color=BLUE]/[/color] *error* axs crv csv des dis inc int lst num obj pt1 rtn tmp )
   ([color=BLUE]defun[/color] *error* ( msg )
       ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]=[/color] 'ename ([color=BLUE]type[/color] tmp)) ([color=BLUE]entget[/color] tmp)) ([color=BLUE]entdel[/color] tmp))
       ([color=BLUE]if[/color] ([color=BLUE]=[/color] 'file ([color=BLUE]type[/color] des)) ([color=BLUE]close[/color] des))
       ([color=BLUE]if[/color] ([color=BLUE]not[/color] ([color=BLUE]wcmatch[/color] ([color=BLUE]strcase[/color] msg [color=BLUE]t[/color]) [color=MAROON]"*break,*cancel*,*exit*"[/color]))
           ([color=BLUE]princ[/color] ([color=BLUE]strcat[/color] [color=MAROON]"\nError: "[/color] msg))
       ([color=BLUE]princ[/color])
   ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] crv (integrate:select [color=MAROON]"\nSelect curve to 'integrate': "[/color]))
            ([color=BLUE]setq[/color] axs (integrate:select [color=MAROON]"\nSelect axis: "[/color]))
       ([color=BLUE]progn[/color]
           ([color=BLUE]initget[/color] 6)
           ([color=BLUE]setq[/color] num ([color=BLUE]cond[/color] (([color=BLUE]getint[/color] [color=MAROON]"\nSpecify number of divisions <10>: "[/color])) (10))
                 dis ([color=BLUE]vlax-curve-getdistatparam[/color] axs ([color=BLUE]vlax-curve-getstartparam[/color] axs))
                 inc ([color=BLUE]/[/color] ([color=BLUE]-[/color] ([color=BLUE]vlax-curve-getdistatparam[/color] axs ([color=BLUE]vlax-curve-getendparam[/color] axs)) dis) num)
                 obj ([color=BLUE]vlax-ename->vla-object[/color] crv)
           ([color=BLUE]repeat[/color] ([color=BLUE]1+[/color] num)
               ([color=BLUE]if[/color] ([color=BLUE]setq[/color] pt1 ([color=BLUE]vlax-curve-getpointatdist[/color] axs dis))
                       ([color=BLUE]setq[/color] tmp
                           ([color=BLUE]entmakex[/color]
                               ([color=BLUE]list[/color]
                                  '(0 . [color=MAROON]"LINE"[/color])
                                   ([color=BLUE]cons[/color] 10 pt1)
                                   ([color=BLUE]cons[/color] 11
                                       ([color=BLUE]mapcar[/color] '[color=BLUE]+[/color] pt1
                                           (   ([color=BLUE]lambda[/color] ( v ) ([color=BLUE]list[/color] ([color=BLUE]-[/color] ([color=BLUE]cadr[/color] v)) ([color=BLUE]car[/color] v)))
                                               ([color=BLUE]vlax-curve-getfirstderiv[/color] axs ([color=BLUE]vlax-curve-getparamatdist[/color] axs dis))
                           ([color=BLUE]setq[/color] int
                               ([color=BLUE]vlax-invoke[/color] obj 'intersectwith
                                   ([color=BLUE]vlax-ename->vla-object[/color] tmp) [color=BLUE]acextendotherentity[/color]
                               ([color=BLUE]setq[/color] lst ([color=BLUE]cons[/color] ([color=BLUE]distance[/color] pt1 int) lst))
                               ([color=BLUE]entmake[/color] ([color=BLUE]list[/color] '(0 . [color=MAROON]"LINE"[/color]) '(62 .  ([color=BLUE]cons[/color] 10 pt1) ([color=BLUE]cons[/color] 11 int)))
               ([color=BLUE]setq[/color] dis ([color=BLUE]+[/color] dis inc))
           ([color=BLUE]if[/color] ([color=BLUE]setq[/color] lst ([color=BLUE]reverse[/color] lst))
               ([color=BLUE]if[/color] ([color=BLUE]and[/color] ([color=BLUE]setq[/color] csv ([color=BLUE]vl-filename-mktemp[/color] [color=MAROON]"int"[/color] ([color=BLUE]getvar[/color] 'dwgprefix) [color=MAROON]".csv"[/color]))
                        ([color=BLUE]setq[/color] des ([color=BLUE]open[/color] csv [color=MAROON]"w"[/color]))
                       ([color=BLUE]write-line[/color] [color=MAROON]"Length 1,Length 2,Segment Width,Segment Area"[/color] des)
                       ([color=BLUE]setq[/color] rtn
                              '([color=BLUE]lambda[/color] ( a b [color=BLUE]/[/color] x )
                                           ([color=BLUE]rtos[/color] a 2 3) [color=MAROON]","[/color]
                                           ([color=BLUE]rtos[/color] b 2 3) [color=MAROON]","[/color]
                                           ([color=BLUE]rtos[/color] inc 2 3) [color=MAROON]","[/color]
                                           ([color=BLUE]rtos[/color] ([color=BLUE]setq[/color] x ([color=BLUE]*[/color] inc 0.5 ([color=BLUE]+[/color] a b))) 2 3)
                                       des
                                   x
                               lst ([color=BLUE]cdr[/color] lst)
                       ([color=BLUE]write-line[/color] [color=MAROON]""[/color] des)
                       ([color=BLUE]write-line[/color] ([color=BLUE]strcat[/color] [color=MAROON]",,Total Area:,"[/color] ([color=BLUE]rtos[/color] ([color=BLUE]apply[/color] '[color=BLUE]+[/color] rtn) 2 3)) des)
                       ([color=BLUE]setq[/color] des ([color=BLUE]close[/color] des))
                       ([color=BLUE]if[/color] ([color=BLUE]findfile[/color] csv) ([color=BLUE]startapp[/color] [color=MAROON]"explorer"[/color] csv))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nUnable to generate CSV file."[/color])
               ([color=BLUE]princ[/color] [color=MAROON]"\nNo intersection data found."[/color])
([color=BLUE]defun[/color] integrate:select ( msg [color=BLUE]/[/color] ent )
   ([color=BLUE]while[/color]
       ([color=BLUE]progn[/color] ([color=BLUE]setvar[/color] 'errno 0) ([color=BLUE]setq[/color] ent ([color=BLUE]car[/color] ([color=BLUE]entsel[/color] msg)))
               (   ([color=BLUE]=[/color] 7 ([color=BLUE]getvar[/color] 'errno))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nMissed, try again."[/color])
               (   ([color=BLUE]null[/color] ent)
                   [color=BLUE]nil[/color]
               (   ([color=BLUE]vl-catch-all-error-p[/color] ([color=BLUE]vl-catch-all-apply[/color] '[color=BLUE]vlax-curve-getendparam[/color] ([color=BLUE]list[/color] ent)))
                   ([color=BLUE]princ[/color] [color=MAROON]"\nInvalid object selected."[/color])
   ent
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
Share this post
Link to post
BIGAL
A property of pline is area so why not make the shape a closed pline ? Use List or Properties to see area
Share this post
Link to post
Lee Mac
Retrieving the enclosed area is of course very easy - I believe the OP is instead looking to demonstrate the convergence on the true area value as the number of divisions increases and the chords better approximate the curve (i.e. a graphical demonstration of integration from first principles).
Share this post
Link to post
bruno_bdan
Hi guys, thank you all for your support!!!
Yes Lee Mac, this is exactly what I want!! Your code is almost there, but is not exactly like this... the code have to execute something like Grrr said. The Lisp have to:
1-) Ask for the Lines. (I mean, "select the lines", something like that, where Lines = Chords cian/blue on my first picture, above)
2-) Execute the ID command over each line, at the intersect point. (The goal here is to Copy the information to paste into a word file)
Take a look on this video. I made everything manually. I belive that It Will clear the Ideas :)
Ps- I'm from Brazil. Here we use "Comma" instead of "Dot" and this is what I did in the video after paste in Word File.
Share this post
Link to post
Lee Mac
Why not use the CSV file data generated by my program?
Share this post
Link to post
bruno_bdan
Is like I said, your code is really almost there, I really liked it! I Loved the fact that the final file is a CSV file!!! So please, what I'd like to ask you to improve in the original code (if possible) are 2 things:
1- ) The results are showed with 3 decimal plates... I'd like 4 ;
2- ) When the CSV file data is created, I'd like that you add one line more, containing the last lenght of all, like this example:
Length_1 , Length_2 ,... etc
Length_2 , Length_3 , ...etc
Length_3 , Length_4 , ...etc
Length_4
Total area ...etc
Thank you again for your help! you have no idea how you are helping me!! :)
Share this post
Link to post
