I had a quick question on editing a LISP routine to allow an argument. As it is currently written, it allows the user to select an xref, and then it opens it as read only. I want to rewrite it so that I can add it to my CUI so when an xref is selected and then I right click I can choose to open it as read only. What function should I use instead of entsel so that the argument accepts the currently selected xref? I have it currently as:
(setq sel (entsel "\nSelect an Xref: "))
Have a read of THIS
Thanks Tharwat! If I understand correctly, I need to add the argument in like this...
(defun c:xopenreadonly (x / other variables) ...rest of code )
. How do I make it so that entsel accepts the argument?
Remove the prefix c: then call it like this:
(if (setq sel (entsel "\nSelect an Xref: "))
 (xopenreadonly sel)
The c: stands for command and the chars that come after the colon would represent the command name so in your case you need a sub-function and not stand-alone program.
 (xopenreadonly sel)
[code]
The c: stands for command and the chars that come after the colon would represent the command name so in your case you need a sub-function and not stand-alone program.[/quote]
So I have tried what you were saying, but I am still having to select an xref. My code is as follows:
(defun c:xopenreadonly2 (/ blk path)
   (xopen sel)
(defun xopen (sel / blk path)
 (setq blk (vlax-ename->vla-object (car sel)))
 (vlax-property-available-p blk 'Path)
 (setq path (vla-get-path blk))
 (setq path (findfile path))
 (vla-activate
   (vla-open (vla-get-documents (vlax-get-acad-object))
      (strcat "\"" path "\"")
      :vlax-true
I guess you need something like this:
Try this [uNTESTED] and let me know.
(defun c:xopenreadonly2 (/ sel)
 (if (setq sel (ssget "_I" '((0 . "INSERT"))))
   (xopen (ssname sel 0))
   (if (and (setq sel (car (entsel "\nSelect an Xref: ")))
            (eq (cdr (assoc 0 (entget sel))) "INSERT")
     (xopen sel)
   (if (and (setq blk (vlax-ename->vla-object sel))
     (vla-activate
                 :vlax-true
That worked perfectly, I just had to make a small tweak. Thank you so much for the help!
     (xopen sel)
     (vla-activate
                 :vlax-true
Excellent. You're welcome.
