Sideshow-Cad Posted January 21, 2016 Posted January 21, 2016 (edited) Hello, I am not versed in the language of LISP. Could someone please edit the following .lsp for me, changing the resultant spreadsheet from feet and inches into metres? Thanks in advance. (defun c:ple (/ elist en i layer layer_list leng pline row ss sumlen total x xlApp xlBook xlBooks xlCells xlSheet xlSheets ) (vl-load-com) (setq xlApp (vlax-get-or-create-object "Excel.Application") xlBooks (vlax-get-property xlApp "Workbooks") xlBook (vlax-invoke-method xlBooks "Add") xlSheets (vlax-get-property xlBook "Sheets") xlSheet (vlax-get-property xlSheets "Item" 1) xlCells (vlax-get-property xlSheet "Cells") ) (vla-put-visible xlApp :vlax-true) ;headers (vlax-put-property xlCells "Item" 1 1 "Layer") (vlax-put-property xlCells "Item" 1 2 "Length") (setq row 2 total 0) (setq ss (ssget "_X" (list (cons 0 "*POLYLINE"))) i -1) (repeat (sslength ss) (setq en (ssname ss (setq i (1+ i))) elist (entget en) layer (cdr (assoc 8 elist))) (if (not (member layer layer_list)) (setq layer_list (cons layer layer_list)))) (repeat (length layer_list) (setq layer (car layer_list)) (vlax-put-property xlCells "Item" row 1 layer) (setq ss (ssget "_X" (list (cons 0 "*POLYLINE")(cons 8 layer))) i -1 sumlen 0) (repeat (sslength ss) (setq row (1+ row)) (setq pline (vlax-ename->vla-object (ssname ss (setq i (1+ i))))) (setq leng (vlax-curve-getdistatparam pline (vlax-curve-getendparam pline))) (vlax-put-property xlCells "Item" row 2 (rtos leng 4 3)) ;;; (vlax-put-property xlCells "Item" row 2 (rtos leng 2 3)); for metric units (setq sumlen (+ sumlen leng))) (setq row (1+ row)) (vlax-put-property xlCells "Item" row 1 "SubTotal:") (vlax-put-property xlCells "Item" row 2 (rtos sumlen 4 3)) (setq total (+ total sumlen)) ;;; (vlax-put-property xlCells "Item" row 2 (rtos sumlen 2 3)); for metric units (setq layer_list (cdr layer_list)) (setq row (+ row 2)) ) ; footers: (vlax-put-property xlCells "Item" row 1 "Total:") (vlax-put-property xlCells "Item" row 2 (rtos total 4 3)) ;;;(vlax-put-property xlCells "Item" row 2 (rtos total 2 3)); for metric units (mapcar (function (lambda(x) (vl-catch-all-apply (function (lambda() (progn (vlax-release-object x) (setq x nil))))))) (list xlCells xlSheet xlSheets xlBook xlBooks xlApp) ) (alert "Close Excel file manually") (gc)(gc) Edited January 21, 2016 by SLW210 Added Code Tags! Quote
Sideshow-Cad Posted January 21, 2016 Author Posted January 21, 2016 (edited) Also, if possible, would the LISP be able to be edited so that in addition to showing the polylines layer, individual length and total length, the CSV also displays the object data associated with each polyline(there are attributes in object data format attached to every polyline) Thanks in advance Edited January 21, 2016 by SLW210 Removed Quote Quote
SLW210 Posted January 21, 2016 Posted January 21, 2016 Please read the Code Posting Guidelines and use Code Tags, I have fixed your posts for now. For the first question, it seems the metric part is included, it is commented out with ;;;. You should just need to comment out the first one (I would add a comment to that for Imperial), then remove the ;;; from in front of the metric version. Example: Current: (vlax-put-property xlCells "Item" row 2 (rtos leng 4 3)) ;;; (vlax-put-property xlCells "Item" row 2 (rtos leng 2 3)); for metric units Change: ;;; (vlax-put-property xlCells "Item" row 2 (rtos leng 4 3)); for Imperial units (vlax-put-property xlCells "Item" row 2 (rtos leng 2 3)); for metric units Quote
