Mirkin Posted January 21, 2016 Posted January 21, 2016 Hi Folks I've drawn a basic dynamic block (attached which is basically just a plate with four holes in it. I can re-size the plate and move the holes around as I need to and I can also scale one of the holes (bottom left). I'm really struggling to find a way to make all four holes scale with one adjustment though. Can anybody suggest a method please. To make it work correctly at the moment to plate has to be resized before the holes but i can work that out later on. Thanks in advance BLANK LAYOUT.dwg Quote
Mirkin Posted January 22, 2016 Author Posted January 22, 2016 Thanks to all those that looked. I managed to work it out in the end. Quote
TheCADnoob Posted January 25, 2016 Posted January 25, 2016 Could you post the solution for the benefit of others? Quote
