Rainbowinthesky Posted January 22, 2016 Posted January 22, 2016 I have a Drawing consisting of Circles / Points with a Unique Text Adjoining each of the Circles / Points. I would like to Associate each Circle / Point with the Text Adjoining to it for the whole drawing. Partial File Attached. Circle Text File.dwg Quote
BIGAL Posted January 22, 2016 Posted January 22, 2016 Dont have code but it can be done by using a block with 1 attribute just search for circle and add text as an attribute. You need to go back one step and next time use a block at the start rather than at end. You are making this dwg somehow a change in method. Quote
guran Posted January 22, 2016 Posted January 22, 2016 You can use the "Auto Constrain" under "Parametric", and constrain all at once Quote
Rainbowinthesky Posted January 23, 2016 Author Posted January 23, 2016 Thanks A Lot To Both Bigal & Guran for there Fast Replies - Both Replies Are Very Helpful - But the Reply by Guran i.e. "You can use the "Auto Constrain" under "Parametric", and constrain all at once" - Worked Out Great - Within A Second All The Text Adjoining Each Of The Circles Got Attached To The Circles Instantly - Wow - That Was Lovely - Thanks A Lot Again Guran & Bigal. Quote
Rainbowinthesky Posted January 23, 2016 Author Posted January 23, 2016 And there were 5000+ Circles with Adjoining Text - All Text Got Attached To Corresponding Nearby Circles in a Second!!! - Thanks A Lot Again. Quote
