[B]Double Quotes within a string[/B]
(setq FILEPATH "D:\\test\\csvextract\\Errorlog.txt") ;[b]FILEPATH[/b] is a variable
I want to write below line as it is to a text file. Assume that is "D:\\dummy.txt"
(see "notepad" "D:\\test\\csvextract\\Errorlog.txt")
I want to use FILEPATH variable to achieve the above line in that text file. please help.
Hi Hari-babu,
use \" , try : (strcat "hi " "Hari-babu") or (strcat "hi "\"Hari-babu\"") to see the difference...
gr. Rlx
typed in command prompt:
Command: (strcat "hi "\"Hari-babu\"")
; error: bad argument type: stringp nil
i have corrected that:
Command: (strcat "hi " "\"Hari-babu\"")
"hi \"Hari-babu\""
But this line is too complex for me. by using a variable filepath.
oops , typed to fast...:oops:
better example : (action_tile "ask" "(setq #RplAddOnStartup \"0\")") , for use in a dialog action tile
(write-line "(setvar \"sdi\" 1)" fp) , for use to write to a script file , so the line written will be (setvar "sdi" 1)
Hopes this is a correct example
gr. Rlx
so far i came until this, but i need another " before D
Command: (strcat "(see " "\"notepad\"" " " filepath ")")
"(see \"notepad\" D:\\test\\csvextract\\errorlog.txt)"
Just see my example :-
(defun c:1 (/ a b c)
 (setq a (getfiled "Specify Output File" "c:/" "txt" 1))
 (setq b (open a "w"))
 (setq c "D:\\test\\csvextract\\Errorlog.txt")
 (write-line (strcat "see \"notepad\" \"" c "\"") b)
 (close b)
 (prompt (strcat "\nFile = " a))
Check it
(strcat "(see \"notepad\" \"" filepath "\")")
:excited:
yes, that is so great for me.
:thumbsup:
Thank You Boss.
