Sort selected entities by shortest distance between start coordinates of each entity
Hello.
Can someone suggest a way to sort a list of selected entities by the shortest distance between end coordinate of one entity and start coordinate of the next?
Here is an example:
yellow points represent the start of entity, and the numbers is the order they should end up.
#1 line is the closest to 0,0; it's end coordinate is closest to arch #2, then polyline #3 and so on.
Thank you.
P.S.
What I'm trying to achieve here is optimize how my plotter draws. It's driver fails to optimize the way it draws, which seems to obey the sequence in which the entities were created in the drawing. Right now I have to manually copy each entity one by one in proper sequence the way I want it to plot...
The problem is essentially the Travelling Salesman Problem (i.e. visiting all nodes following the shortest path). Below is a solution implementing a nearest-neighbour greedy algorithm - note that this approach will not yield the optimal result:
(defun sortentlist ( lst / foo rtn )
   (setq foo
       (lambda ( x l / a d r )
           (setq d (distance (caddr x) (cadar l))
                 r (car l)
           (foreach y (cdr l)
               (if (< (setq a (distance (cadr y) (caddr x))) d)
                   (setq d a r y)
           r
   (setq lst (mapcar '(lambda ( x ) (list x (vlax-curve-getstartpoint x) (vlax-curve-getendpoint x))) lst)
         rtn (list (car lst))
         lst (cdr lst)
   (while lst
       (setq rtn (cons (foo (car rtn) lst) rtn)
             lst (vl-remove (car rtn) lst)
   (reverse (mapcar 'car rtn))
The algorithm could also be implemented using sorting, but this will be less efficient:
(defun sortentlist ( lst / rtn )
         lst (cdr lst)
   (while lst
       (setq lst (vl-sort lst '(lambda ( a b ) (< (distance (caddar rtn) (cadr a)) (distance (caddar rtn) (cadr b)))))
             rtn (cons (car lst) rtn)
Lee was this not another post problem how to make the laser cutter do the next closest item saving head movement time.
