I am new to script writing and am trying to make one that will replace the title block in a couple hundred files. I have all files and dwgs in a folder named bctest on my c: drive(c:\bctest). I'll make an example list below.
a.102.0.01.dwg
a.103.1.07.dwg
a.104.1.01.dwg
etc.......
kbi P&idTblk.dwg
bctest_update.bat
bctest_update.lsp
bctest_update.scr
script file
INSERT "kbi P&IDTblk"=c:\bctest\A* Y ^C^C
0,0 1 1 0
ERASE L
(load "c:\\bctest\\bctest_update.lsp")
bctest_update
QUIT
Y
lisp file
(defun c:bctest_update(/ dn pa panbdn)
(setq dn (getvar "dwgname"))
(setq pa (getvar "dwgprefix"))
(setq panbdn (strcat pa "new\\" dn))
(command "save" panbdn )
batch file
md c:\bctest\new
for %%f in (c:\bctest\A*.dwg) do START/WAIT c:\"program files"\"autodesk"\"Autocad 2015"\acad.exe "%%f"/b c:\bctest\bctest_update.scr
When i initiate the bat file it creates a folder named new, opens up acad, then cannot find any of the files.
I've attached a snapshot of the errors that come up.
I am new to all of this. So any help would be great
thanks for your help.
Hey there, welcome to the forum. Normally you get faster responses than this, though the scripts part of the forum can be a forgotten corner sometimes.
I applaud your efforst to automate this!
Can we strip a few parts out of this process to troubleshoot?
First, does the script work if you run it manually on an open dwg?
Next, can you run the batch file in a test area where you don't create another foler called "New"? Just input and output from the same folder, fo rtesting.
See what comes of that, and hopefully we can narrow down where the error could be.
Script does not work manually.
do i just delete this part of the batch? md c:\bctest\new
and then run it?
Thanks YZ
I would write the script in a form that can be read simply then carry out the changes via a lisp, you add your code to say acaddoc.lsp this way it autoloads and is available for every dwg 2nd example loads lisp each time, I think your over complicating what you are trying to do. What about delete existing title block ? Your script part has a number of errors
open dwg1 (bctest_update) close n
open dwg2 (bctest_update) close n
Ok now some help from Windows go to the START lower left type CMD you will open a command window.
cd \bctest
dir *.dwg >dirlst /b
you now have a list of every dwg in your bctest directory as a text file
Open dirlst with word
using search/replace
replace ^p with ^popen
you now have
open dwg1
open dwg2
replace ^p with (load "bctest") close n^p
you now have
open dwg1 (load "bctest") close n
open dwg2 (load "bctest") close n
save as a text file bctest.scr
and then run it?
Thanks YZ
To test the script in AutoCAD type "Script" in command line, and browse to the script file, and click "Open".
If the script does not do what you want it to do on one of your drawings, then that is the first place to troubleshoot. Work on the batch file later.
