samifox Posted January 26, 2016 Posted January 26, 2016 hi is there a way to set the units of imported xref to be equal to the host drawing's units? Thanks Shay Quote
RobDraw Posted January 26, 2016 Posted January 26, 2016 Yes. UNITS will get you to the dialog box version. Quote
samifox Posted January 26, 2016 Author Posted January 26, 2016 i know . for example, if my host is in Milimeter and the xref is in Cantimeter, the xref will be scaled. i want to avoid 1. going back to the the xref 2. unit it to milimiters 3.saving 4. going back to the host 5.import dwg again thanks Quote
RobDraw Posted January 26, 2016 Posted January 26, 2016 So, you are saying that you want to avoid having to do what you need to do in order get the units the same without scaling? That would be a neat trick. Quote
samifox Posted January 26, 2016 Author Posted January 26, 2016 So, you are saying that you want to avoid having to do what you need to do in order get the units the same without scaling? That would be a neat trick. it could be lisped. but lisp is the last resort. just want to make sure Autodesk didnt provide non-lisp oprion to achive the above. thanks Quote
rkmcswain Posted January 26, 2016 Posted January 26, 2016 i know . for example, if my host is in Milimeter and the xref is in Cantimeter, the xref will be scaled. i want to avoid 1. going back to the the xref 2. unit it to milimiters 3.saving 4. going back to the host 5.import dwg again thanks Set everything to unitless. INSUNITS INSUNITSDEFSOURCE INSUNITSDEFTARGET Quote
samifox Posted January 26, 2016 Author Posted January 26, 2016 Set everything to unitless. INSUNITS INSUNITSDEFSOURCE INSUNITSDEFTARGET i notice that when i set INSUNITS to 0, no scale take place. but i couldn’t get the logic of INSUNITSDEFSOURCE and INSUNITSDEFTARGET. do they control the direction of the units inheritance?, meaning, when the host is going to adopt the units type of the xref (INSUNITSDEFSOURCE) and vise versa. honestly, even now when asking im not really finding full sense of what im talking about. can anyone make an order in this issue? Quote
rkmcswain Posted January 26, 2016 Posted January 26, 2016 Maybe I misunderstood. I thought you were trying to avoid "auto-scaling" Personally, if I want something scaled, I'll do it myself. That's just me. Quote
RobDraw Posted January 26, 2016 Posted January 26, 2016 Personally, if I want something scaled, I'll do it myself.That's just me. You're not alone. Trying to work with different units gets me confused. Kind of like working in two platforms (Revit and AutoCAD) at the same time. Quote
samifox Posted January 26, 2016 Author Posted January 26, 2016 yes you did help me avoid scaling when the xref is unitless, can anyone explain to me what is the logic behaind INSUNITSDEFSOURCE INSUNITSDEFTARGET ? ? Quote
