newchurchr Posted January 26, 2016 Posted January 26, 2016 Is there away to select multiple polylines with multiple depths all at once? I need to select certain polylines that are every 5 foot apart in elevation and not every single one in between. I know you can use quick select to pick all the polylines on one depth at a time but i want to do multiple depths at one time. Is there a quick way to do this? Quote
Dadgad Posted January 27, 2016 Posted January 27, 2016 You can try the "FILTER" command. Murph is absolutely right! FILTER is a very useful command, once you get the hang of it, but it is not nearly as new user friendly as most new functionalities. If you create a filter which you may want to use another time, SAVE it, as creating the filters is what takes the most time. On a subsequent use you can access the SAVED FILTERS drop down arrow, and you are off to the races without further ado. Quote
newchurchr Posted January 27, 2016 Author Posted January 27, 2016 Thanks! this command was not user friendly but i got it now. Quote
Murph_map Posted January 28, 2016 Posted January 28, 2016 Thanks! this command was not user friendly but i got it now. Right it is not very friendly to new users that's why I attached the image of the dialog to help give you an idea on what to do. Aslo if you are using AutoCAD Map3D there are a few other ways to get what you want but the filter command works just as well. Quote
