Happy Hobbit Posted February 2, 2016 Posted February 2, 2016 I've found this DCL by Kenny Ramage which I intend adapting for a delete entities lisp. I intend to replace "Bolt Holes &Site" with "Points", "Bolt Holes Sho&p" with "Very Short Lines" etc etc samp4 : dialog { //dialog name label = "Structural Holes" ; //give it a label :boxed_radio_column { //define radio column label = "Type" ; //give it a label : radio_button { //define radion button key = "rb1" ; //give it a name label = "Bolt Holes &Site" ; //give it a label value = "1" ; //switch it on } //end definition : radio_button { //define radio button key = "rb2" ; //give it a name label = "Bolt Holes Sho&p" ; //give it a label } //end definition : radio_button { //define radio button key = "rb3" ; //give it a name label = "Bolt Holes &Hidden" ; //give it a label } //end definition : radio_button { //define radio button key = "rb4" ; //give it a name label = "Bolt Holes &Ctsnk" ; //give it a label } //end definition : radio_button { //define radio button key = "rb5" ; //give it a name label = "Bolt Holes &Elevation" ; //give it a label } //end definition : radio_button { //define radion button key = "rb6" ; //give it a name label = "Bolt Holes &Slotted" ; //give it a label } //end definition } //end radio column ok_cancel ; //predifined OK/Cancel : row { //define row : image { //define image tile key = "im" ; //give it a name height = 1.0 ; //and a height width = 1.0 ; //and now a width } //end image : paragraph { //define paragraph : text_part { //define text label = "Designed and Created"; //give it some text } //end text : text_part { //define more text label = "by Kenny Ramage"; //some more text } //end text } //end paragraph } //end row } //end dialog What I'd like is for all the radio butons to be checked by default, I can then de-select any I wish before clicking OK. What do I have to change/add to make all the radio buttons checked? Quote
Lee Mac Posted February 2, 2016 Posted February 2, 2016 Use toggle tiles in place of radio_button tiles; radio_buttons are intended for selection of a single item. To enable the toggle without user input, use: (set_tile "yourtogglekey" "1") Or set the DCL value attribute to "1". Quote
Happy Hobbit Posted February 2, 2016 Author Posted February 2, 2016 Nice one Lee, thanks for that Quote
