How to Draw An Ellipse Inside A Rectangle Like This?
Drawing an ellipse inside a rectangle like this is easy, piece of cake:
However, how do you draw an ellipse inside a rectangle like this (acad file is attached)?
How do you find the center point of the ellipse inside this rectangle, please tell me step-by-step and draw the construction line.
Ellipse.dwg
I can't view your images at work.
What is in your drawing is a non rectangular parallelogram, a rectangle has 4 right angles (90°).
You will need to manually construct an ellipse in that one I believe. http://draftingmanuals.tpub.com/14276/css/14276_119.htm
Could you please tell me step-by-step using autocad?
A Video perhaps?
Are you drawing something is perspective?
What is this for exactly?
How was the object that you drew constructed?
There is no single solution.
The center point is anywhere on the line between diagonal's midpoints.
The intersection between the 2 lines connecting opposite tangent points is constant and equal to diagonal's intersection.
In the attached dwg, select the ellipse and drag from it's centerpoint.
ellipse.dwg
[ATTACH]56863[/ATTACH]
Cool Demo.:thumbsup:
