Hsanon Posted February 3, 2016 Posted February 3, 2016 i had this issue of text in blocks which when mirrored, well... the text mirrored too. on scrounging the forum, i was told that if we convert the text into attributes, the text will not mirror. i tried that,.... but the text i the block just refuses to be visible... in the normal block and the mirrored block... the attribute is not "invisible" as a property. If you refedit the block all attributes are visible. i am sure there is a small variable in play which i am not being able to figure out.... also, how can we have the attribute in lower case ??? and can anything be done to have the correct placement of text when the block is mirrored over a horizontal axis ???? attaching the mirrored block as a sample.. thanks .... mirrored text in block.dwg Quote
steven-g Posted February 3, 2016 Posted February 3, 2016 Run the attsync command, and select your block, that should solve your problems. If you insert a new block it should be ok as well. Quote
satishrajdev Posted February 4, 2016 Posted February 4, 2016 Or You can use battman command also Quote
Hsanon Posted February 4, 2016 Author Posted February 4, 2016 done chief.... i dont know why it didnt work the first time.... had tried attsync yesterday too... however, its working now... many thanks for your help. (and the bonus is that the text attrib's can be grip edited for movement .... thats a bonus which i had not expected ) Quote
