I am trying to find the best way (or any way) to manipulate data in a different window than you started with.
I basically have created a new DWG file, which is also the Active Window and now I want to save it. I cannot just use
ThisDrawing.SaveAs Filename
because it will save the original drawing. I know the new drawing becomes the active window, so if there is a way to switch to the active window, then that will be good too.
Is that clear? Is what I am asking possible?
Thanks.
Thanks.
You dont need the "active window" thing; this isnt scripting.
"ThisDrawing" is easy, and the default, but you can, and should, use your own variable names when dealing with multiple drawings.
When you created your new DWG file, you should set a variable to it, and use the variable to reference it; something like this:
Sub main()
   Dim FirstDwg As AcadDocument
   Dim SecondDwg As AcadDocument
   ' set the variable "FirstDwg" to some drawing you opened from disk:
   Set FirstDwg = Application.Documents.Open("c:\MyTestDwg.dwg", False)
   ' set the variable "SecondDwg" to a drawing you create new:
   Set SecondDwg = Application.Documents.Add()
   ' activate the first drawing and zoom extents
   FirstDwg.Activate: ZoomExtents
   ' Pop up the name of the active layer, in the second drawing, without  activating it
    MsgBox SecondDwg.ActiveLayer.Name
   '  clear the Object variables before leaving the sub
   Set FirstDwg = Nothing
   Set SecondDwg = Nothing
End Sub
Thanks for the help. I tried following your rules in the situation I have; but I cannot seem to get the active window selected. Can you help determine what the next line would be to save the window that pops up?
I have also attached the project, in case you need to see it.
Private Sub ImportButton_Click()
   ThisDrawing.SendCommand "filedia" & vbCr & "0" & vbCr
   ' Set filedia to 0
   ThisDrawing.SendCommand "import" & vbCr & "C:\Test.dgn" & vbCr & "" & vbCr & "" & vbCr & "" & vbCr
   'Import File dgn file
   ThisDrawing.SendCommand "filedia" & vbCr & "1" & vbCr
   ' Set filedia to 1
End
'Close Window
End Sub
Thanks again.
Import_Test.zip
