error: bad argument type: stringp nil?
this lisp i found somewhere on the internet ... when i run it this error pops up
any help ?
; Legend - EMT Software Inc., by Scott Hull 04/18/01
(defun C:LEGEND (/ #ALERT #DCL-FILE #DCL-ID #DCL-LIST #GO #HELP #LEGEND-BLOCK
#LEGEND-LAYER #LINENO @ALERT @DWGLYRS @LAYER @LIST @LEGEND-DRAW
@LEGEND-READ @LEGEND-WRITE *error*)
(setq #DCL-LIST (list
"legend : dialog {"
" key = \"title\";"
" label = \"Legend Generator\";"
" : boxed_column {"
" label = \"&Layers\";"
" : concatenation {"
" : text_part {"
" label = \"Name\";"
" width = 19;"
" : text_part {"
" label = \"Legend\";"
" width = 9;"
" : text_part {"
" label = \"Description\";"
" : list_box {"
" height = 8;"
" key = \"layer\";"
" tabs = \"19 28\";"
" width = 70;"
" : row {"
" : edit_box {"
" edit_width = 60;"
" fixed_width = true;"
" key = \"descp-layer\";"
" label = \"&Description:\";"
" : boxed_column {"
" label = \"&Blocks\";"
" : text_part {"
" width = 19;"
" : text_part {"
" width = 9;"
" : text_part {"
" : list_box {"
" height = 8;"
" key = \"block\";"
" width = 70;"
" : row {"
" : edit_box {"
" edit_width = 60;"
" key = \"descp-block\";"
" ok_cancel_help_cadalog_errtile;"
"cadalog_button : retirement_button {"
" key = \"cadalog\";"
" label = \"&CADalog.com...\";"
"ok_cancel_help_cadalog : column {"
" : row {"
" alignment = centered;"
" ok_button;"
" : spacer {"
" width = 2;"
" cancel_button;"
" : spacer {"
" width = 2;"
" help_button;"
" : spacer {"
" width = 2;"
" cadalog_button;"
"ok_cancel_help_cadalog_errtile : column {"
" ok_cancel_help_cadalog;"
" errtile;"
(setq #HELP (strcat
"Legend Generator\n\n"
"Allows you to add text descriptions to create a legend for blocks and \n"
"layers. The programs stores descriptions in two files, legend-block.tbl \n"
"and legend-layer.tbl so they can be reused later.\n\n"
"Blocks and layers that are present in the current drawing or in an XREF \n"
"can be used but XREF blocks and linetypes that cannot be found in the \n"
"current drawing table will not display in the legend. Instead, any blocks \n"
"that are not found will have a text marker placed in the legend, and any \n"
"linetypes that are not found will use the CONTINUOUS linetype.\n\n"
"The text for the legend is based on the current setting of the AutoCAD \n"
"TEXTSIZE system variable. Block scales are derived from existing blocks \n"
"used in the drawing.\n\n"
"You can enter different descriptions for blocks and layers in XREFs that \n"
"use the same name as the base drawing but the descriptions from the base \n"
"drawing will take precedence when the legend program writes the two tbl \n"
"files for later use."))
(if (not V:LEGEND_DIR)
(setq V:LEGEND_DIR
(strcat (vl-filename-directory (findfile "legend.lsp")) "\\")))
(defun *error* (%A)
(if (= (type V:FILE) 'FILE) (close V:FILE))
(cond
((= %A "Function cancelled") nil)
((and V:FILENAME (= %A "malformed string"))
(princ (strcat "\nerror: check file - " V:FILENAME)))
(t (princ (strcat "\nerror: " %A "\007\n"))))
(princ))
(defun @ALERT0 (%STR)
(if (not #ALERT) (setq #ALERT ""))
(setq #ALERT
(strcat #ALERT "Linetype " %STR " is not loaded - used CONTINUOUS\n")))
(defun @ALERT1 (%STR)
(setq #ALERT
(strcat #ALERT "Block " %STR " is not loaded - used text w/block name\n")))
(defun @BASE (%A / #POS)
(setq #POS (vl-string-position 124 %A))
(if #POS (substr %A (+ #POS 2)) %A))
(defun @FORMAT (%A / #CHR #COUNT #LEN #STR)
(setq #COUNT 0 #LEN (strlen %A) #STR "")
(repeat #LEN
(setq #COUNT (1+ #COUNT) #CHR (substr %A #COUNT 1))
(if (= #CHR "\"") (setq #CHR "\\\""))
(setq #STR (strcat #STR #CHR)))
(eval #STR))
(defun @DWGLYRS (/ #LINE #LYR #LYRNAME #X1 #X2)
(setq #LYR (tblnext "layer" 1))
(while #LYR
(setq #LYRNAME (strcase (cdr (assoc 2 #LYR))))
(if (setq #LINE (assoc (@BASE #LYRNAME) (cdr TBL:LEGEND-LAYER)))
(setq #LEGEND-LAYER (cons (list #LYRNAME (cadr #LINE) (caddr #LINE)) #LEGEND-LAYER))
(setq #LEGEND-LAYER (cons (list #LYRNAME 0 "") #LEGEND-LAYER)))
(setq #LYR (tblnext "layer")))
(setq #LEGEND-LAYER
(vl-sort #LEGEND-LAYER (function (lambda (#X1 #X2) (< (car #X1) (car #X2)))))))
(defun @DWGBLKS (/ #LINE #BLK #BLKNAME #X1 #X2)
(setq #BLK (tblnext "block" 1))
(while #BLK
(setq #BLKNAME (strcase (cdr (assoc 2 #BLK))))
(cond
((assoc 1 #BLK) nil)
((= (substr (@BASE #BLKNAME) 1 2) "*U") nil)
((setq #LINE (assoc (@BASE #BLKNAME) (cdr TBL:LEGEND-BLOCK)))
(setq #LEGEND-BLOCK (cons (list #BLKNAME (cadr #LINE) (caddr #LINE)) #LEGEND-BLOCK)))
(T (setq #LEGEND-BLOCK (cons (list #BLKNAME 0 "") #LEGEND-BLOCK))))
(setq #BLK (tblnext "block")))
(if #LEGEND-BLOCK (setq #LEGEND-BLOCK
(vl-sort #LEGEND-BLOCK (function (lambda (#X1 #X2) (< (car #X1) (car #X2))))))))
;draw legend
(defun @LEGEND-DRAW (/ #CLAYER #PT0 #PT1 #SCALE #TEXTSIZE #X
@DRAWBLK @DRAWLINE @DRAWTXT @INSERT)
(setvar "cmdecho" 0)
(setq #CLAYER (getvar "clayer")
#TEXTSIZE (getvar "textsize"))
;%A - block name
(defun @DRAWBLK (%BLKNAME / #0 #BLK #DATA #EXIST #LYR #SCALE #SIZE #SS #TMP @SIZE)
(defun @SIZE (%ENT / #MAXP #MINP)
(vla-getboundingbox (vlax-ename->vla-object %ENT) '#MINP '#MAXP)
(setq #MINP (vlax-safearray->list #MINP)
#MAXP (vlax-safearray->list #MAXP))
(- (cadr #MAXP) (cadr #MINP)))
(setq #BLK (@BASE %BLKNAME)
#EXIST (tblsearch "block" #BLK)
#SS (ssget "_X" (list (cons 2 #BLK))))
(if #SS
(setq #0 (ssname #SS 0)
#DATA (entget #0)
#LYR (cdr (assoc 8 #DATA))
#SCALE (cdr (assoc 41 #DATA))))
(cond
((not #EXIST)
(@ALERT1 #BLK)
(@DRAWTXT "m" (polar #PT1 0 (* #TEXTSIZE 6.5)) #BLK)
(@DRAWTXT "ml" (polar #PT1 0 (* #TEXTSIZE 15)) #TEXT)
(setq #PT1 (polar #PT1 (* 1.5 pi) (* #TEXTSIZE 4))))
((and #EXIST (not #0))
(setq #SCALE 1.0 #SIZE #TEXTSIZE #LYR (getvar "celayer"))
(@INSERT #BLK #PT1 #LYR #SCALE))
(#0
(if (not vla-getboundingbox) (vl-load-com))
(setq #SIZE (@SIZE #0))
(if (> #SIZE (setq #TMP (* 3 #TEXTSIZE)))
(setq #PT1 (polar #PT1 (* 1.5 pi) (setq #TMP (* 0.5 (- #SIZE #TMP)))))
(setq #TMP nil))
(if #TMP
(setq #PT1 (polar #PT1 (* 1.5 pi) (+ (* #TEXTSIZE 4) #TMP)))
(setq #PT1 (polar #PT1 (* 1.5 pi) (* #TEXTSIZE 4)))))))
(defun @INSERT (%BLK %PT %LYR %SCALE / #CECOLOR #CELTYPE #COLOR #DATA
#LTYPE)
(setq #CECOLOR (getvar "cecolor")
#CELTYPE (getvar "celtype")
#DATA (tblsearch "layer" %LYR)
#COLOR (cdr (assoc 62 #DATA))
#LTYPE (@BASE (cdr (assoc 6 #DATA))))
(if (not (tblsearch "ltype" #LTYPE))
(@ALERT0 #LTYPE)
(setq #LTYPE "CONTINUOUS")))
(if (= (type #COLOR) 'INT) (setq #COLOR (itoa #COLOR)))
(setvar "cecolor" #COLOR)
(setvar "celtype" #LTYPE)
(command "_.insert" %BLK "_none" (polar %PT 0 (* #TEXTSIZE 6.5)) %SCALE %SCALE 0)
(setvar "cecolor" #CECOLOR)
(setvar "celtype" #CELTYPE))
;draw line
(defun @DRAWLINE (%LYR %PT / #CECOLOR #CELTYPE #COLOR #DATA #LTYPE)
(@ALERT0 #LTYPE)
(command "_.line" "_none" %PT "_none" (polar %PT 0 (* #TEXTSIZE 13)) "")
;draw text
(defun @DRAWTXT (%JUST %PT %TXT)
(if (= (cdr (assoc 40 (tblsearch "style" (getvar "textstyle")))) 0.0)
(command "_.text" (strcat "_" %JUST) "_none" %PT "" 0 %TXT)
(command "_.text" (strcat "_" %JUST) "_none" %PT 0 %TXT)))
(initget 1)
(setq #PT0 (getpoint "\nLegend insert point: ")
#PT1 (polar #PT0 (* 1.5 pi) (* #TEXTSIZE 4)))
(@DRAWTXT "m" (polar #PT0 0 (* #TEXTSIZE 14)) "LEGEND")
(foreach #X #LEGEND-LAYER
(if (= (cadr #X) 1)
(if (= (setq #TEXT (caddr #X)) "") (setq #TEXT "???"))
(@DRAWLINE (car #X) #PT1)
(foreach #X #LEGEND-BLOCK
(if (= (cadr #X) 1)
(@DRAWBLK (car #X))))))
;write legend table
(defun @LEGEND-WRITE-LAYER (%LGND / #BASE #LEGEND2 #X)
(setq #LEGEND2 %LGND
V:FILENAME (strcat V:LEGEND_DIR "legend-layer.tbl")
V:FILE (open V:FILENAME "w"))
(foreach #X (cdr TBL:LEGEND-LAYER)
(if (not (assoc (car #X) #LEGEND2))
(setq #LEGEND2 (append #LEGEND2 (list #X)))))
(write-line "\"LAYER\" \"LEGEND\" \"DESCP\"" V:FILE)
(foreach #X #LEGEND2
(setq #BASE (@BASE (car #X)))
(if (and
(/= (caddr #X) "")
(or (= #BASE (car #X)) (not (assoc #BASE #LEGEND2))))
(write-line
(strcat "\"" (@BASE (car #X)) "\" "
(itoa (cadr #X)) " \"" (@FORMAT (caddr #X)) "\"")
V:FILE)))
(close V:FILE))
(defun @LEGEND-WRITE-BLOCK (%LGND / #BASE #LEGEND2 #X)
V:FILENAME (strcat V:LEGEND_DIR "legend-block.tbl")
(foreach #X (cdr TBL:LEGEND-BLOCK)
(write-line "\"BLOCK\" \"LEGEND\" \"DESCP\"" V:FILE)
(if (and
(/= (caddr #X) "")
(write-line
(strcat "\"" #BASE "\" "
V:FILE)))
(close V:FILE))
;sets table and returns current legend table as a list
(defun @LEGEND-GET-LAYER (/ @TABLE V:FILE V:FILENAME)
(defun @TABLE (/ #A #B #C #FILE)
(setq #A T
#FILE "legend-layer.tbl"
V:FILENAME (findfile #FILE)
V:FILE (open V:FILENAME "r"))
(while #A
(setq #A (read-line V:FILE))
(cond
((and #A (/= (substr #A 1 1) ";")
(setq #C (read (strcat "(" #A ")"))))
(setq #B (cons #C #B)))))
(close V:FILE)
(reverse #B))
(if (findfile "legend-layer.tbl")
(setq TBL:LEGEND-LAYER (@TABLE))
(setq TBL:LEGEND-LAYER (list (list "LAYER" "LEGEND" "DESCP")))))
(defun @LEGEND-GET-BLOCK (/ @TABLE V:FILE V:FILENAME)
(setq #A T
#FILE "legend-block.tbl"
(while #A
(cond
(close V:FILE)
(reverse #B))
(if (findfile "legend-block.tbl")
(setq TBL:LEGEND-BLOCK (@TABLE))
(setq TBL:LEGEND-BLOCK (list (list "BLOCK" "LEGEND" "DESCP")))))
(defun @LIST-LAYER (/ #X)
(start_list "layer")
(add_list (strcat (car #X) "\t" (if (= (cadr #X) 1) "X" "")
"\t" (caddr #X))))
(end_list))
(defun @LIST-BLOCK (/ #X)
(start_list "block")
"\t" (caddr #X))))
(end_list))
(defun @LAYER (%A %B %C / #CASR #CADDR #CHECK #LINE0 #LINE1)
(setq #LINENO (atoi %A)
#LINE0 (nth #LINENO #LEGEND-LAYER)
#CHECK (cadr #LINE0))
(cond
(%B
(mode_tile "descp-layer" #CHECK)
(setq #CADR (abs (1- #CHECK)) #CADDR (caddr #LINE0)))
(%C
(setq #CADR (cadr #LINE0) #CADDR %C))
(T
(mode_tile "descp-layer" (abs (1- #CHECK)))
(setq #CADR (cadr #LINE0) #CADDR (caddr #LINE0))))
(setq #LINE1
(list (car #LINE0) #CADR #CADDR)
#LEGEND-LAYER (subst #LINE1 #LINE0 #LEGEND-LAYER))
(@LIST-LAYER)
(set_tile "layer" %A)
(set_tile "descp-layer" (caddr (nth #LINENO #LEGEND-LAYER)))
(if (and %A (= #CHECK 0)) (mode_tile "descp-layer" 2)))
(defun @BLOCK (%A %B %C / #CHECK #LINE0 #LINE1)
#LINE0 (nth #LINENO #LEGEND-BLOCK)
(cond
(%B
(mode_tile "descp-block" #CHECK)
(%C
(T
(mode_tile "descp-block" (abs (1- #CHECK)))
(setq #LINE1
#LEGEND-BLOCK (subst #LINE1 #LINE0 #LEGEND-BLOCK))
(@LIST-BLOCK)
(set_tile "block" %A)
(set_tile "descp-block" (caddr (nth #LINENO #LEGEND-BLOCK)))
(if (and %A (= #CHECK 0)) (mode_tile "descp-block" 2)))
(if (not (findfile (setq #DCL-FILE (strcat V:LEGEND_DIR "legend.dcl"))))
(setq #FILE (open #DCL-FILE "w"))
(foreach #X #DCL-LIST (write-line #X #FILE))
(close #FILE)
(alert #HELP)))
(if (< (setq #DCL-ID (load_dialog "legend")) 0) (quit))
(if (not (new_dialog "legend" #DCL-ID)) (quit))
(@LEGEND-GET-LAYER)
(@LEGEND-GET-BLOCK)
(@DWGLYRS)
(@DWGBLKS)
(@LIST-LAYER)
(@LIST-BLOCK)
(@LAYER "0" nil nil)
(if #LEGEND-BLOCK
(@BLOCK "0" nil nil)
(progn (mode_tile "block" 1) (mode_tile "descp-block" 1)))
(set_tile "layer" "0")
(action_tile "accept" (strcat
"(@LEGEND-WRITE-LAYER #LEGEND-LAYER)"
"(@LEGEND-WRITE-BLOCK #LEGEND-BLOCK)"
"(done_dialog 1)"))
(action_tile "cadalog" "(done_dialog 2)")
(action_tile "descp-layer" "(@LAYER (itoa #LINENO) nil $value)")
(action_tile "descp-block" "(@BLOCK (itoa #LINENO) nil $value)")
(action_tile "help" "(alert #HELP)")
(action_tile "layer" "(@LAYER $value T nil)")
(action_tile "block" "(@BLOCK $value T nil)")
(setq #GO (start_dialog))
(cond
((= #GO 1)
(@LEGEND-DRAW)
(if #ALERT (alert #ALERT)))
((= #GO 2) (command "_.browser" "www.cadalog.com")))
(princ))
Legend.dcl
legend : dialog {
key = "title";
label = "Legend Generator";
: boxed_column {
label = "&Layers";
: concatenation {
: text_part {
label = "Name";
width = 19;
: text_part {
label = "Legend";
width = 9;
: text_part {
label = "Description";
: list_box {
height = 8;
key = "layer";
tabs = "19 28";
width = 70;
: row {
: edit_box {
edit_width = 60;
fixed_width = true;
key = "descp-layer";
label = "&Description:";
: boxed_column {
label = "&Blocks";
: concatenation {
: text_part {
label = "Name";
width = 19;
: text_part {
label = "Legend";
width = 9;
: text_part {
: list_box {
height = 8;
key = "block";
tabs = "19 28";
width = 70;
: row {
: edit_box {
edit_width = 60;
fixed_width = true;
key = "descp-block";
key = "cadalog";
label = "&CADalog.com...";
: row {
fixed_width = true;
ok_button;
: spacer {
width = 2;
cancel_button;
: spacer {
width = 2;
help_button;
: spacer {
width = 2;
cadalog_button;
errtile;
From this point down is dcl code not lisp code remove and try again its a copy of the code above
Legend.dcl
still have the error after removing the dcl code from it ... any suggestions ?
Load the code into the VLIDE.
Run it from AutoCAD.
You get the error "; error: bad argument type: stringp nil"
Now return to the VLIDE
Choose View > Error Trace.
That opens the Error trace window.
On line 2 of that window, you can see that the error is on this line:
If you right-click on there, and choose Call Point Source, it will take you to the line of the code where the error is occurring.
So it looks like this file must be saved as "Legend.lsp" and be located in the support file search path. I did this and it runs okay now.
Edited by rkmcswain
add URL
works good now ..
thanks rkmcswain , BIGAL
thanks alot
